Cars & Trucks Logo
w
wayne shelton Posted on Mar 24, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fuses label peugeot expert 2002
I need to know what all the fuses are for in the glove box on my 2002 peugeot expert van where will i find the label
ka4iup
Level 3:
  • Peugeot Master 4,062 Answers
  • Posted on Apr 30, 2015
ka4iup
Peugeot Master
Level 3:
Answers
4062
Questions
0
Helped
1096652
Points
51404
This information will be contained in the owner manual, which can be downloaded from here:
http://www.repairservicemanuals.com/Peugeot/
loginek
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Peugeot Master 1,075 Answers
  • Posted on Jul 10, 2016
loginek
Peugeot Master
Level 3:
Renaissance:
Answers
1075
Questions
0
Helped
1320515
Points
4975
5 Related Answers
Anonymous
  • 5158 Answers
  • Posted on Feb 01, 2009
SOURCE: peugeot expert van heater blower not working
check the heater resister block located on the duct work near the fan that may have failed
Q4SteveB
  • 159 Answers
  • Posted on Feb 10, 2009
SOURCE: i need a fuse box
Try Amazon.co.uk (or your local Library) & search books for the "Haynes Manual" ..
Anonymous
  • 301 Answers
  • Posted on Oct 28, 2009
SOURCE: Peugeot Expert Van Cambelt change
Most cam belts need to be changed every 60,000 miles. I would change again somewhere around 126,000.
alicantecoli
Colin Stickland
  • 22516 Answers
  • Posted on Nov 01, 2009
SOURCE: Need to sync my central locking key to peugeot
then you need a copy of alldata ,sorry i have ordered one in english but my courier isnt coming out till january.(my friend rodger) Dealers can do this for you though but the charge??
Anonymous
  • Posted on Jan 11, 2010
SOURCE: peugeot speedo mileage counter and speedo dont
Had this problem on mine & the main dealer were stumped. Eventually found it myself after a lot of pocking about.Have a look at the wiring loom in the engine compartment. Looking under the bonnet look closely on the right hand side of the engine above the gearbox where the wiring loom passes from the rear of the engine over a metal bracket/support to the front. The loom has a tendancy to rub against the bracket and eventually damage the cables within. You will have to remove the air filter canistor & a few air hoses to get to the bracket. Good luck!
2answers
2013 Peugeot Expert Utility Van. Is there a air bleeder release cap on a Peugeot Expert and where would it be please?
Various Coolant Air bleed caps on Peugeot in the link. Of course, you may mean brakes, clutch, steering pump, or fuel. In which case modify the Google search query.
https://www.google.com/search?q=Peugeot+expert+coolant+air+bleeder+location
1helpful
How do I gain access to the fuse box in the passenger well of a Peugeot partner van 2013
Could be at the back of the glove box. Open the glove box and open the fuse box.
My windscreen wiper jets have stopped working on my Peugeot expert van 2015 plate. Don't know if a fuse has blown? Has anyone else had this problem?
Fuses under the bonnet
Peugeot Expert mk2 - under bonnet Fuse Ampere rating [A] Functions 1 20 Engine control unit, Fuel supply and air supply systems, Fan assembly 2 15 Horn 3 10 Front and rear wash-wipe pump 4 20 Headlamp wash pump 5 15 Fuel supply system 6 10 Power steering, Secondary brake pedal switch 7 10 Braking system (ABS/ESP) 8 20 Starter control 9 10 Main brake pedal switch 10 40 Fuel supply and air supply systems, Emission control systems 11 40 Front ventilation 12 30 Windscreen wipers 13 40 Built-in systems interface 14 30 Not used
Here's the under the bonnet fuses #3 is the one your looking to see if it's blown.
hope this helps a little.
if no diagram on the box lid or the manual go here..
http://www.autogenius.info/peugeot-expert-tp-mk2-2008-2014-fuse-box-diagram/
1helpful
My indicators have packed up completely on my Peugeot Expert Van it ws registered in 2006
First I'd look at the fuse box... next the column stalk..
You'll need a 12v tester and continuity tester for the fuse.
1helpful
2answers
Where do I find the number for the side mirror fuse of a Peugeot 407 ST Saloon. The hand book does not list the number?
Not an expert on Peugeot but the fuses should be labelled on the inside of the fuse box cover. Failing that just remove each fuse one by one to see which is blown.
1helpful
Hi, I have a peugeot 206 2005 diesel and the windscreen washers aren't working. They don't even make a noise so i assume the fuse has blown with the recent cold weather? Does anybody know which fuse it is?...
The fuse box is inside the glove box (on passenger side dash board).
Open the glove box and you'll then see a small box on the side with a Plastic screw on it. Turn the screw to 90° to open the fuse box. Which fuse it could be for washer motor i really don't know as peugeot service manual has not lost any word about fuse plan.
Hi we have a peugeot 406 2002.could you please advise me on how i can find whare the fuse box is located in the car
The cabin fuse box is integrated in the glove box. Open your glove box and on the door side you'll see a part-box with a big plastic screw on it. Move this screw to 90° and open the cover of fuse box.
4helpful
2answers
Where is bonnet catch situated on citreon dispatch
its at the very bottom of the dash line most are orange but I had the peugeot expert ( same van reall) and it was black on the passenger side right under the glove box part, I have seen them on both sides of these vehicles so just look along the very very bottom of the dash. its only small though about 4 inches long and 1 inch wide.
I need a fuse box layout for a peugeot expert van Y reg
Top Peugeot Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Arnie Burke
Arnie Burke
Are you a Peugeot Expert? Answer questions, earn points and help others
