Question about ASUS P5LD2-VM Motherboard
Shut down... Please help, I have been playing with this system months, trying to get it to run right. I've exchanged the motherboard, tried different memory, exchanged the power supply, changed the processor, the case, I am at my wits end. My problem is basically, at first it will run good the 1st day. Then when I go to use it the next day, after about half hour it just shuts off. I'm running Vista Ultimate, currently has a 2.8G Core2 , 2x512 DDR2 400mhz, Antec 900 Case, Antec TruePower 2.0 430W. I've checked the Temp and power using PCProbeII and it looks fine, THe CPU doesn't go higher than 116F Peak, usually average at 85F???
  • 87 Answers
I am not getting into ur point what u want actually?
Posted on Nov 18, 2007
Unable to connect PS3 to linksys wrt300n, key exchange timed out, signal 100% and key is correct?
For instructions on setting up the PS3, Xbox, or Wii, for a wireless/Internet connection. please click on this link :- http://fixhomenetwork.com/xbox-play-station-wii.php
Dec 08, 2012 | Linksys Wireless-G WRT54G Router
My son bought a xbox360 from his friend a few days ago an we just got him halo reach an it says we need a 4-digit password we've tried over 100 different combination to play halo or C.o.D morning so we...
Now this depends from system to system so you might have to try a couple of these but....
Go to system Then Console settings Then System info Then try one of these following combinations
LEFT TRIGGER, RIGHT TRIGGER, X, Y, LEFT BUMPER, RIGHT BUMPER
LEFT TRIGGER, RIGHT TRIGGER, X, Y, LEFT BUMPER, RIGHT BUMPER, Y, LEFT STICK CLICK, Y, Y LEFT TRIGGER, RIGHT TRIGGER, X, Y, LEFT BUMPER, RIGHT BUMPER, D-PAD UP, A, X, A
LEFT TRIGGER, RIGHT TRIGGER, X, Y, LEFT BUMPER, RIGHT BUMPER, LEFT STICK CLICK, X, X
Hopefully one of them works. After that, it should tell you to reset the factory settings, just hit yes and you should be fine.
Cheers
Jun 19, 2011 | Microsoft Xbox 360 Console
My computer powers up for 1 sec then shuts off its using a intel dg41cn mother board i diconnected and removed all hdwr except cpu and it will run steady and post a 3 beep bio i then installed the grafix...
Gd morning
O.k are you building a new system...the memory you are using is it the original memory,if so try a new stick or try it in a different bank..
Is the memory compatable with the motherboard i.e the memory you should be using is DDR...
how big is the memory...
Try this link
http://www.intel.com/p/en_US/support/highlights/dsktpboards/dg41cn
Hope this help....please rate this as i,ve taken the time and trouble to help...if i can be any more help..
Regards
Apr 03, 2011 | Computers & Internet
The computer make a large beep sound whent it is turning on and never boot. I tried with different memory cards but did not work. help me please
Is the monitor working,
can you see the bios post
are you sure there is power
are the fans running
did it show any errors
blue screen
blue screen error
have you tried to enter safe mode and run system restore.
Feb 11, 2010 | Biostar U8668D (802700113338) Motherboard
Asus P5B -E Plus motherboard Beeping during bootup (Repost)
If you are hearing the code right. 1 then 3 you can have a cpu bad or bad memory, remove memory or find (borow) new. try that, also try a new battery Time error. Then start from scratch - take everything loose from the board nothing but the board, one stick of memory, no hard drive, no video card, if you get the same code your cpu is going. If you get different code try the video card if you get the old code thats the problem. Clear as mud? Yep clear as mud.
Jul 28, 2009 | ASUS P5B-E Motherboard
Cannot play copied games in psp's memory stick after updating
Hi Aneeshameeda
I think the best solution is to downgrade your PSP system software to the original version and check if your games load. What might have happened is that the firmware software that was on the PSP was downgraded to play copied games, and now you've changed the firmware to a newer version and that is why your games won't load. You might hac=ve to get your PSP downgraded again to play the games from your memory card.
Nov 11, 2008 | Sony PlayStation Portable (PSP) Console
My pc freezes :(
Hi redjeans21,
There can be a verity of reasons that can cause you to loose display. I'll list some suggestions you can try that may fix this issue. After each suggestion try the game that freezes the system more often than the others. (If you have never cleaned the inside of your system please do so). Use canned air & blow out the guts of the motherboard & power supply).
First, please make sure your antivirus software is up to date & run a full system scan. If you need a virus scanner you can download & install AVG for free at this link. http://free.avg.com/ww.download-avg-anti-virus-free-edition Once you are sure your system is clean let’s run a test on your system memory. Click on the link below to download memtest86 software. http://memtest.org/
Scroll down the page until you see three monitor snap shots. Download either. (Suggest the floppy software which is the easiest to use). For bootable floppy disk test software download, (Download - Pre-Compiled package for Floppy (DOS - Win). To create bootable CD test software, (Download - Pre-Compiled Bootable ISO (.zip). Boot your system with either disk, floppy or CD & test your memory. You'll know if there is a problem & you'll know what you need to do. (Let’s hope its ok).
The integrated VGA video card is not the greatest for playing games. The reason it is not is because the onboard video uses your system memory to function. Part of your 512MB of system memory goes to your video card & windows XP needs all of the 512MB. It's suggested that an XP system run with 1GB. 512MB is still ok. System freezes are more likely caused by software, including registry errors. Download & run this free registry cleaner. http://www.pctuneuptips.com/recommends/clean/?gclid=CL2RiIrTmpICFSFMGgodODIPzg
Restart your system after the cleaner has finished. Next try running windows check disk. Right click once on My Computer & slide to & left click Open. Right click on C: & slide to & left click Properties.
Left click the Tools tab & than click, Check Now... for Error-checking. Your system will restart & run check disk. Lastly, buy an AGP graphics card & disable the onboard video. The MSI KM4M-L motherboard can only run an AGP card that supports 1.5 volts. This link is a 1.5v AGP card:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4097741&CatId=318
The card above comes with a 2 year warranty.
More AGP's: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2145957&CatId=318
If nothing above has helped or fixed the freezing issue, I would do a fresh install of windows, including a format of the hard disk drive.
Good luck redjeans21!
Mike
Sep 19, 2008 | MSI KM4M-L Motherboard
Double boot
almost anything is possible, but in general a 430 watt P/S should be able to run 2 gigs of ram, however that doesn't mean that the ram you purchased is the correct ram for the motherboard or that you have so many other added perpherials i.e. dual or tripe CD drives, hard drives, USB perpherials that the load is simply to great for your P/S. A rule of thumb is find out what your system ' will ' run with and then work from there. For example if a person was serous about this problem he might disconnect all power connectors to all other equipment other then his hard drive, monitor/video card, and his motherboard just to see if the system could then boot normally. If it did, chances are the memory is okay for the motherboard in normal circumstances. However if the system did not boot normally, it might be an incompatibility with the 2 gigs of memory on that particular motherboard. Memory is not a generic add-on. A person needs to make sure the memory is correct for a motherboard before installing. Also you indicate the present P/S is only 4 months old, any particular reason why you had it changed out to begin with??
Feb 27, 2008 | Biostar P4M80-M4 Motherboard
Lying ipaq H5550!
It's a problem with either the memory board or the button board. With my h5550, the bottom buttons started to stop working and eventualy the PPC stoped charging all together. You can find parts for it online. If all the buttons are working fine, then it's most likely the motherboard. Otherwise it should be the button board.
Dec 29, 2007 | HP iPAQ H5550 Pocket PC
JUST SHUT DOWN
Does the CPU fan spin when you press the switch? If it doesnt, short the green wire from the power supply with the black one, If the fan still does not spin, the power supply is bad. If it does, the mother board has a problem.
Please get back after this test.
Regards,
Anand
Dec 17, 2007 | ASUS P5S800-VM Motherboard
ASUS P5LD2-VM Motherboard Logo
57 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
