Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
Password i forgot my security key and i cant connect threw my router how can i reset it
  • 3 Answers
this is easy just look at the back of your router and there will be a small hole, just push a pin into it for longer then 6 Sec's and Bingo your router will be reset back to factory settings again (NO WEP etc), hope this helps you, and don't forget to reset your WEP and MAC up again will you. dont forget to rate me if u like my solution
Posted on Nov 13, 2007
Forgot my password
Reset the Linksys to default settings using the manual: http://homekb.cisco.com/Cisco2/ukp.aspx?vw=1&docid=1e97db4854604b0fb5cc8c0d74491e35_19584.xml&pid=96&slnid=3 Reconfigue the SSID and Security. You may want to write down the Security Key (password) for future use. A tattoo is optional, it's up to you.
Dec 31, 2012 | Linksys Wireless-G WRT54G Router
I cant connect to my wifi i forgot my security key
Hello.
You just need to reset your router so you don't have to put any password anymore. To reset it, find the reset button, it is really small and you have to use a pin to be able to press it. Hold the reset button down for 10 seconds.
Depending on your router, it usually can be found here:
Jul 18, 2011 | Computers & Internet
What will i do if i forgot my security key???
All you have to do is connect to the router and change security key/ secure the connection. Just follow the following steps: -
First you have to access the router through web browser (Internet Explorer) by typing the IP address of your router in the address bar, which is 192.168.0.1 (Default router settings are written under the router)
(unless you've configured otherwise, the default username is admin and the password "leave it blank") and lookup for the options to do the following: -
Next step is to secure it:
1.On the left-hand side, under Setup, click "Wireless Setup" 2.Under "Wireless Security Mode", select your desired encryption method (preferably WPA2-PSK)
3.Choose a Network Key - it can be anything, as long as it's 8-63 characters in length
4. Click Save Settings.
1. Change the SSID (Name) of the router
2. Change the default administrative user name and password
(The above step would prevent unauthorized access to your router)
Now your router and your connection would become secure and the user has to provide the network key to access the internet.
In case you have forgotten the User Name/ Password of the router, there is no way to recover the lost password However, you can reset the router to factory defaults and re-configure settings like password, network key etc. First, to reset the router to factory default setting, press the reset button at the back of the router.
Please note that after RESETTING THE ROUTER to defaults, ALL SETTINGS WILL BE LOST AND YOU HAVE TO RECONFIGURE IT. Generally, after hard reset you get the connectivity, however, you have to make the connection secure etc.
Please, refer here to download the product guide/manual and make configurations as per the details provided by your Internet Service Provider (ISP).
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 01, 2011 | D-Link AirPlus DI-524 Wireless Router
I forgot the security key
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Jun 25, 2011 | Linksys WRT120N Router
Forgot the password i tried so many times but incorrect allthe times
You will want to try
username: admin
password: admin
username: admin
password: 1234
username: admin
password: password
If these dont work you will want to reset the router back to defaults.
Mar 01, 2011 | NetGear WGR614 Wireless Router
How to change my password... i forgot my password now i cant share my connection good thing my iphone remmemvers the router
I assume you previously enabled security on your router, so you are now trying to retrieve the security key so that other computers can make connections via that router.
The security key should be in the computer which configured the router, as well as any computer which made a wireless connection to the router. It may be available in the web-based configuration page for the router (if you are able to access that).
Alternative, you should be able to retrieve the security key, by installing some additional (free) software on any computer that has connected
to the router.
WirelessKeyView
by NirSoft
http://www.nirsoft.net/utils/wireless_key.html
Feb 13, 2011 | Encore ENHWIN3 Wireless Router
I dont know the code forgot the code for other computers to get conecct like a ipone for the computer
Welcome to Fixya. If you forgot the code or the Network Key (Passphrase) we can access the Wireless Settings Page of the router to obtain the information needed to connect your iphone.
To access the router page you need a working computer that is connected to the router. To access your router you need to use a computer that is connected to it. Open a Browser then type 192.168.0.1 or http://routerlogin.net. The Default username is admin and the password is password. Password is case sensitive.
Go to the Wireless Tab select Wireless Security under the Security Mode you will see there Network Key or Passphrase. The Network Key serves as a password or security code on your network to make it secure. Network Key is case sensitive.
Don't forget to say thanks. Thanks for using Fixya
Feb 07, 2011 | NetGear Computers & Internet
I forgot my pass word
Pressing and holding the Reset button for 15-20 seconds should reset your router to its original condition, ie., with the factory default logon/password. You'll have to re-enter any changes you may have made to your specifications, but you'll then be able to reset your password.
Dec 28, 2010 | D-Link DIR-615 Wireless Router
Forgot password to log on for my wireless connection trying to add my Wii and now cant even get my laptop back online
You can check the passphrase when you access the router page:
  • Open a Web browser and type http://gateway.2wire.net or http://192.168.1.254; the 2Wire Home page opens.
  • Click the Home Networking tab at the top of the 2Wire Home page.
  • Click on Wireless Settings. then click EDIT SETTINGS located on the right panel.
  • Here you will be able to fine the setting for your wireless connection
  • You can change the SSID, Wireless Channel, Wireless Security, and Network Key
  • If the Wireless Security Key uses the default, the Passphrase is the 10 digits located underneath the router under the S/N.
Thanks for using Fixya.
May 13, 2010 | Computers & Internet
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
246 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
