Question about Dell 3100cn Laser Printer
3100cn: not printing .25in strip about .75in from right edge.
  • leckybill Jan 16, 2008
    I have exactly the same problem as you Glenjamine. Anyone out there got a solution?
  • delllllllll Jan 19, 2008
    I am having the same problem. I was able to use the cleaning swiper thing on the right to fix it once for about 100 pages, but now it's back. NEED HELP! HAVE WORK DUE ON MONDAY!
    An expert whose answer gotĀ voted for 100 times.
  • 188 Answers
This printer problem is usually fixed by one of the following two solutions.
1) The Cyan cartridge is not seated 100% correctly. If the locking handle is not seated correctly, the printhead is obstructed from properly developing the the black developer at the extream right hand side. When reseated, the light can then see past the handle and place the image properly.
2) The printhead is dirty ( usually toner dust) and needs to be cleaned. To clean the printhead, open the front cover, pull back on the blue handle on the right hand side. This opens the cover to the cleaning wand on the right hand side of the printer. Gently pull the cleaning wand ALL the way out, and then slide back in ALL the way. Do NOT just move the wand back and forth. this will just push the debris around. The wand is designed to move across the printhead in only one direction. When you pull it out to its full extent, it is lifted up so that when you push it back, it is actually above the glass, not on it. When it reaches its full inward position, it drops back down to go over the glass again from left to right.
Make sure that you change this cleaning pad each time you change the imaging unit ( a new pad is included with the new drum).
Important note: If cleaning the printhead works, but then the print fades out again after a short period of usage, a more serious problem exist in which one of the photo developers is leaking. This is not a user replaceable part. The color of the defective developer would correspond to the color of the cleaning pad after cleaning.
Posted on Sep 28, 2008
When printing, the toner does not completely get distributed. Consequently we are left with a "white" line through the print on the right-hand side. The white begins about 7/8ths inches in from edge and...
It can either be the toner cartridge itself, or the fuser.
Try a full cleaning, and if that does not help at all, you will have to replace the toner or fuser or both.
Apr 07, 2010 | Dell 3100cn Laser Printer
Our Dell 3100CN printer blocks out a 1/2" wide line (all colors) print area on the right side. We replaced the printer drum unit and that didn't fix the problem. It was printing fine until we replaced the...
Try the cleaning rod. visit:
for images (under replacing the "cleaning rod pad") for where to find the cleaning rod. You likely don't need to replace the pad, just use the rod (pull out and push in 10X) and try to print again.
Oct 22, 2009 | Dell 3100cn Laser Printer
Far right side of the text or picture missing on Dell 3100cn.
Refer to the following table
How common*
Contamination in the laser path
1. Clean the laser path. (Remove the laser/scanner assembly and clean the lens.) 2. Replace the laser/scanner assembly
Defective fuser.
Replace the fuser assembly
Lack of toner or faulty toner cartridge.
Redistribute the toner in the toner cartridge. If the problem continues, replace the toner cartridge.
Sep 30, 2009 | Dell 3100cn Laser Printer
Documents are printing fine but the right hand edge has black dots on it like 6-8 sapced out along the right hand edge.
check your print cartridge and your fusing element. you will need to dead cycle the printer to check the cartridge (print a document, when it is half way through turn off the printer, check the toner cartridge for your dots.) are you able to see your fusing element by opening the rear door? check the edges for dots on the fusing element. also there is a transfer roller or belt in your printer, that may also be dirty.
Sep 24, 2009 | Dell 3100cn Laser Printer
Dell 3100cn printer leaves a blank strip
The following table should help
Contamination in the laser path - 1. Clean the laser path. (Remove the laser/scanner assembly and clean the lens.) 2. Replace the laser/scanner assembly
Defective fuser - Replace the fuser assembly.
Lack of toner or faulty toner cartridge - Redistribute the toner in the toner cartridge. If the problem continues, replace the toner cartridge.
Dirty Corona Wire - Clean the Corona Wire.
Defective Drum - Mostly applies to B&W printers. Clean the drum or replace the drum.
Sep 20, 2009 | Dell 3100cn Laser Printer
Dell 3100 CN Prints a stip on black all the way
There is a known issue for these printers to "streak." If under warranty, call Dell. If not, there is a fix
for the defective drum unit design but requires a little technical expertise.
The procedure is explained here:
Jul 08, 2009 | Dell 3100cn Laser Printer
Streaks on left side
Jan 20, 2008 | Dell 3100cn Laser Printer
Right side no yellow ink
You can get the manuals for the 3100cn printer from the Dell support website ( They include some troubleshooting steps for determining what is causing a number of different problems with the printer. Did you make sure there was nothing blocking the toner on that side of the toner cartridges you replaced? If you haven't already tried it, I would also suggest cleaning the printer to see if that fixes the print problems you are seeing. The User's Guide (in the link above) has a section describing how to do this. If that doesn't fix things, run the tests for print quality and contact Dell support (contact information is in the manual, or on the website). Hopefully this will help you get the problem fixed if you haven't already done so. Larry Dell Customer Advocate
May 17, 2007 | Dell 3100cn Laser Printer
Dell 3100cn Laser Printer Logo
275 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
