Ruud UAMB Air Conditioner Logo
K
Ken Fowler Posted on Mar 23, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the seer rating for a 1997 ruud ac/heat unit model urka-a030jk06e?
Wally Gonzzlez
Level 2:
New Friend:
  • Expert 52 Answers
  • Posted on Mar 26, 2015
Wally Gonzzlez
Expert
Level 2:
New Friend:
Answers
52
Questions
Helped
14851
Points
124
More than likely less than 13 seer too old
5 Related Answers
Anonymous
  • 54 Answers
  • Posted on May 30, 2008
SOURCE: ruud achiever 10 seer air conditioner
It sounds like your condenser fan motor may be locked up or the capacitor that helps give the condenser fan motor a kick to get it started may be defective. Try turning your system on and using a long screwdriver try to push the fan blade on the condenser fan motor to see if it will run normally if you give it the starting boost it needs.If it does run at full speed and doesn't over heat or start and then slow down then you probably only need to replace a simple 10-12$ capacitor. If it barely turns, makes an odd humming sound or overheats etc. then you will have to replace the condenser fan motor. This is assuming that the outdoor condenser has the 220v supplied and the 24v supplied to the compressor relay, that the compressor relay is engaged and suppling 220v to the condenser fan motor.
muttandjeff
Allen Neal
  • 359 Answers
  • Posted on Nov 24, 2008
SOURCE: model #uacc 030jas - BTU/H and SEER
that is a three ton unit and most likely a 10 seer rated seer rating are posted 6 months in cool and 6 months in heat to get the number on the unit if you are more interested in heating rating of heat pumps the aher or annual heating efficiency rating is of the most importance in this category the unit posted very well
pierre1811
Perry Putnam
  • 144 Answers
  • Posted on Mar 22, 2009
SOURCE: ruud 12 seer heat pump not heating
It sounds like the unit is tripping off from high pressure. Check you filter and indoor coil. You may have low air flow inside that is causing the refrigerant pressure to be to high.
Anonymous
  • 242 Answers
  • Posted on Apr 10, 2009
SOURCE: capacitor unable to read what size
If it's the condenser fan motor cap then look at the label on the fan motor for the size usally 3/5 mfd.
If its the compressor run cap then check the top of the compressor or the info. plate/sticker on the unit for the size of the cap. Let me know if you have any other questions.
Phil
Anonymous
  • 4 Answers
  • Posted on Aug 16, 2009
SOURCE: RUUD Acheivers Series AC unit
The reset is two pins on the defrost board. Put a flat scredriver across them to reset the board.
Could you tell me what ton unit this model number is 13ajn30a01
2.5 Ton 13 Seer Ruud Air Conditioner Condenser
The AC Outlet https://www.theacoutlet.com > 13ajn30a01-2-5-ton-13...
Outdoor condensing unit designed for ground level or rooftop installations. These units offer comfort and dependability for single, multi-family and light ...
I have a Ruud AC DATE: 12/00 Model:
Here is a tip about trouble shooting your air conditioner...
I would check the air filter and the blower motor...
sounds like a problen with one of them...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
I have a ruud rcha 36a2g heat pump from 2004. What is the seer rating and tonnage of it? Also inscribed uhbc-17jo6nfh
The unit is a 3 ton or around 36,000 BTU
It also is around a 10 SEER could be a abit more depending on the maych up of the coil and airhandler or furnace combination...
Heatman101
Model #uacc 030jas - BTU/H and SEER
Top Ruud Heating & Cooling Experts
john h
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
