Question about Dell XPS Computers & Internet
Why can't I upload pics to my eBay? Keeps showing amd adapter msg?
I tried restarting in safe mode as suggested by forum but problem pursists...
  •  Tech Thatworks
    Tech Thatworks Mar 23, 2015
    Hi Tim Henault, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What is the message you are getting? Also do you get the same message if you try to upload to Facebook or similar sites?
SOURCE:
wafirash
  • 63 Answers
SOURCE: possible virus?????
i think your computer infected by virus..
try to cleanup by using Avast antivirus..
try to download from website www.cnetdownload.com
its mayb can help u..
good luck..
Posted on Apr 20, 2008
sandrew
  • 2961 Answers
SOURCE: system will not load, keeps restarting ,will not go into safe mode
it may be cycling, when the system reboots, press and hold the power button, to completely switch off, then turn back on as normal
Posted on Aug 17, 2008
jelacio
  • 10 Answers
SOURCE: computer keeps restarting in safe
IT CAN BE
OVERHEATING
1: CPU
2: NO FAN IN SIDE THE SYSTEM
3: POWER SUPPLY RUNNING TO HOT
4: HARD DRIVE FAILURE - the smart feature would cause the hard drive to reboot and if the power supply had been running hot sounds like it might have been hit by a surge
Posted on Aug 20, 2008
Ownij
  • 67 Answers
SOURCE: unable to reboot
Sounds to me like you have a bad or dying power supply. Try finding a friend with a working power supply and hook it up to your computer, if the problem ceases, then go get yourself a new power supply. If the problem persists, it may be an issue with cables or the fuse, maybe even a bad motherboard.
Posted on Mar 12, 2009
  • 86 Answers
SOURCE: Acer-Veriton M410 - US 3800P AMD Desktop PC - AMD
F8 tap it when screen name comes on
Posted on Aug 13, 2009
Testimonial: "thanks that worked"
Toshiba Satellite L355-S7812 keeps restarting with AC Adapter plugged in
Your OS has a corrupt element in it that makes unit shut down every once in a while. Try repairing the OS. Or try a system restore. If nothing works and it still bugs you reload the unit.
Sep 06, 2017 | Computers & Internet
Dell Inspiron 6400. Error 0F00:0244. On startup I get "disk read error, press ctrl+alt+del to restart. What do? I had a problem with the Ac adapter, it kept failing and powering the laptop down...
Your hard drive might be on the way out
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive
you should have no input while chkdsk utility is in progress any input might further damage your computer or
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file.
Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
hope this helps
Sep 13, 2012 | Computers & Internet
Keeps restarting does not bootup in safe mode also
if safe mode does not work, try OS repair or reinstalled. This can indicate a corrupted OS. If reinstalling does not work either, it may indicate hardware failure. Try to isolate it by removing and reconnecting all components like RAM, hard disk, CD or DVD drive, battery and AC adapter and see how it goes.
Oct 07, 2010 | Acer TravelMate 240 Notebook
Display problem
welcome to the forum! From safe mode open 'display properties', then 'settings'. It should show a screen area of 640 x 480 and 16 colors. Click 'apply' and 'OK'. It should give you a message that you're changing the settings for normal mode. Click to confirm that. Then shut down and restart in normal mode. It should boot OK to thedesktop.
Then you need to figure out what happened. Since they were both the same laptop the video drivers should be the same, or was one of the laptops using an external monitor?
Check in device manager and see if it shows a problem with the video adapter. If so you may need toreinstall the video drivers. If not, try the recommended video settings for the laptop.
May 21, 2010 | Computers & Internet
Display problem
hi raju knowu
Check in device manager and see if it shows a problem with the video adapter. If so you may need to reinstall the video drivers. If not, try the recommended video settings for the laptop.
May 21, 2010 | Acer AL1716 F Monitor
Memory card showing 'no image' after trying to upload
Sounds like you didn't use the "safely remove hardware" function when you disconnected the USB cable. This can corrupt the card and even the camera. You could try using a separate card reader to download the pics from the card. If that works, and the pics are safely downloaded, then you should format the card in the camera to erase and optimize it. If it doesn't work, take the card to a Walmart that has a Kodak Picture Kiosk and it should be able to read your card. You can print the pics or even make a cd of them. Then, format the card in the camera.
Apr 01, 2010 | Olympus FE-370 Digital Camera
I get a message, "Frequency out of range. Nothibng else. The menue and other buttons don't do anything. Nothing else shows. I swapped out the monitor and the new one works.
This problem arise when your computer AGP driver not adjust monitor frequency.you fix it restart your computer and run safe mode settings resolution area(must be choice less area)or select 1024X768 pixel monitor frequency 60Hz press apply set OK.restart your computer.Run again normal mode.May be fix your problem.
Dec 27, 2009 | Princeton Digital VL1916 19" LCD Monitor
My computer keeps restarting with the following msg showing - We apologise for the inconvenience but windows did not start successfully. A recent hardware and software change may have caused this. What can...
Hi !
Thank you for choosing the Fixya.com
Cause: A thirdparty driver/software crashing the windowing subsystem. Windows hascome up with a kernel change that, if Windows crashes, it'll reboot themachine rather than going to the blue screen.
Step 1: Firstunplug all the external devices, like printer, internet connection,camera, external harddrive etc. Isolate the machine with keyboard,mouse, monitor & that's all should be connected to the machine.
Step2:Now, restart the machine try to boot in to the Windows Advanced MenuOption by pressing the F8. Try disabling "Automatic restart on systemfailure, So that you can get the BSOD & the troubleshootaccordingly. Need more help about, how to boot in to Safe Mode, checkthis article:
http://support.microsoft.com/kb/316941
Step3: If you are able to boot in to the Safe Mode, Check if you can undothe changes that caused this problem, If you can't remember. Try SystemRetore.
http://support.microsoft.com/kb/306084
Step 4: Still no joy, Configure the computer in Clean Boot.
http://support.microsoft.com/kb/310353
Also, perform Windows Update & 80% of time it'll fix it for you.
Hope this will be helpful.
Regard's
Anurag Shukla
Sep 08, 2009 | Computers & Internet
Winsys32 problem
Try rebooting int SAFE MODE or last known good profile. Once able to login, just undo the changes made. You can recopy the setup files using windows CD update. If nothing helps just mail me.
Jun 07, 2008 | Microsoft Windows XP Professional for PC
Open Questions:
Computers & Internet Logo
81 people viewed this question
Clive
Clive
Alun Cox
