Question about Sony DVDirect (VRDVC20) DVD±RW Dual Layer Burner
Lexmark x1270 printer
Cannot get it to download right or at all
Re: lexmark x1270 printer - Sony DVDirect (VRDVC20) DVD±RW Dual Layer Burner CD & DVD Burners
Posted on Feb 14, 2008
0 characters
3 Points
Install epson ink without cd installer
You can download the Epson printer drivers from their support WEB site. Please click on this link and select your model printer to download :-
Mar 30, 2013 | Epson L200 Original Continuous Ink Tank...
Three light on my printer when power on
check of what you see in your computer monitor about your printer, if there's a dialog box appear to your screen that say: service required or waste ink tank full your printer is already meet the duration period it means you need to reset or adjust the firmware of your printer there is some downloadable adjustment program for that. just search to the net about resetter of your printer
Jan 17, 2013 | Epson L200 Original Continuous Ink Tank...
General error L200, what is solution? I try to turn off and switch again...It Error again..
Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes, turn the printer back on. but not working printer.
Sep 30, 2012 | Epson L200 Original Continuous Ink Tank...
Epson L200 unable to turn on?
make sure all leads connected to printer have secure connections
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port
you might see a yellow? ! question exclamation mark or a red X this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope this helps
Apr 29, 2012 | Epson L200 Original Continuous Ink Tank...
Need driver for windows vista home
if this package is not the right
on the home page you should see a search tab just type in what you are looking for
(be precise)also the download software finder under that there will be a list place a tick in the box of any one you want/need
all software windows software mac software mobile and web apps
also this link will provide you with many freeware and share drivers
hope this helps you
Aug 09, 2011 | SySTOR Systems SySTOR DiscMaster 101P - 50...
Lost disc to download on to my computer to use my printer lexmark 4300
open laxmark website and go to support then download and select your printer model number and download the driver and install them on your computer an printer will be work fine.
Mar 23, 2010 | CD & DVD Burners
Dvd clashes witm my software of my printer
On the back of the drive is a jumper for M (master) S (slave) CS (cable select)
It sounds like that may be in the wrong position.
If you have two devices trying to be Master or two trying to be slave that will make boot up very slow or not at all.
Double check how the cables and jumpers are arranged.
Mar 10, 2010 | HP DVD1040i 20x Super Multiformat Dvd...
How can I install as my disk appears faulty?
go to lexmark and down load the drivers from them
Aug 03, 2009 | CD & DVD Burners
Sony DVDirect (VRDVC20) DVD±RW Dual Layer Burner Logo
19 people viewed this question
Top Sony CD & DVD Burners Experts
Brian Sullivan
Brian Sullivan
Shahzad  Waseem...
Shahzad Waseem...
Are you a Sony CD and DVD Burner Expert? Answer questions, earn points and help others
