Cars & Trucks Logo
Sean Posted on Feb 27, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2012 mini cooper s, w/ alarm and cimfort access. Alarm, comfort access, interior lighting not working. When I have pass side door open cat will lock, drivers side door open doors will not lock. Open rear hatch and rear lights come on only. Would the oass sude lick actuator cause this?
toddgilbert
Level 3:
Top Expert:
  • Mini Master 6,360 Answers
  • Posted on Mar 15, 2018
toddgilbert
Mini Master
Level 3:
Top Expert:
Answers
6360
Questions
5
Helped
1523400
Points
27737
Best thing go to www.reliable-store.com they have got books on every vehicle and also how to service/repair it,
service/repair/owner's/maintenance manual with
parts info, fuse box, gear box, PCV, torque specs,coiling, wiring diagrams, electrical diagrams, fuse diagrams, error codes, etc everything
Worth it
5 Related Answers
gfischer21
George Fischer
  • 236 Answers
  • Posted on Jun 17, 2009
SOURCE: 2003 Honda Pilot Door locks not working
may be a relay switch, or a faulty wire on the right side behind the glove box
Anonymous
  • Posted on Jul 25, 2009
SOURCE: rear hatch door won't lock dash light showing
You need to tighten the lock mech on the boot lid. this will close the boot just enough more to turn the light on. It's no biggy, you might need a star driver depending on bolt head. move it into the boot lid approx 4mm to start. then 1mm until 10mm. if no joy then it may be the sensor.
All the best
Ally A
jamie
  • 1810 Answers
  • Posted on Jan 22, 2010
SOURCE: 2002 VW Golf TDI open door light & alarm
check door switches remove 1 at a time and unplug it once you find the bad switch lights will go out
un plug 1 at a time
Anonymous
  • Posted on Mar 09, 2010
SOURCE: rear hatch 2005 chevy tahoe is locked & won't open
my 06 tahoe just got this problem...all other doors lock and unlock with the fab and door switch...but the hatch is in permanent locked mode. i cant even unlock the hatch window. why is this happening?
Anonymous
  • 6468 Answers
  • Posted on Aug 15, 2012
SOURCE: 2004 Highlander rear hatch sets off the alarm.
the switch is bad on the rear hatch cylinder
Testimonial: "Thanks, that sounds about right. I will open up the panel this weekend and try to get a look at it. I took it to two different dealers and they could not figure that out. Looks like a replacement is only about $70."
Interior car alarm wont stop
It can be any of the car doors not got properly locked or the door is locked but the switch is not sensing the door locked. Open and close each door again properly.
Or else its problem with any of switch wiring getting in contact with alarm wiring causing it to happen.
And last thing alarm connections need to be inspected. It's getting short somewhere in between.
There is a help link with solutions, to troubleshoot these types of problems. I suggest going through these link.
Click the link below: ------
CAR ALARM ISSUES
http://alltypesofpartsreplacing.blogspot.com/2012/11/factory-alarmsecurity-system-alarmcar.html
These will help.
Thanks.
I replaced a battery in my 2001 pontiac montana n the lights started blinking as if the alarm was going off.i hit the unlock n lock button n the blinking stopped. i have power,lights n radio but van wont...
There are few help links with solutions, to troubleshoot these types of problems. I suggest going through these links.
Volvo car alarm keeps going off for no reason
http://technoanswers.blogspot.in/2012/07/volvo-car-alarm-keeps-going-off-for-no.html
Alarm keeps going OFF
http://technoanswers.blogspot.in/2012/07/alarm-keeps-going-off.html
2009 Toyota Camry: Hood Switch causing Alarm to go OFF?
http://whatisbyme.blogspot.in/2012/04/2009-toyota-camry-hood-switch-causing.html
Ford Pickup Alarm will not disengage?
http://technoanswers.blogspot.com/2012/01/ford-pickup-alarm-will-not-disengage.html
Mitsubishi Diamante: Factory Security Alarm will not go Off
http://www.howtorepairguide.com/2012/11/mitsubishi-diamante-factory-security.html
Toyota Avalon Factory Alarm will go off?
http://repairhelpcenter.blogspot.com/2012/01/toyota-avalon-factory-alarm-will-go-off.html
Chevrolet Tahoe Hood open warning on dash and alarm sounds?
http://schematicsdiagram.blogspot.com/2011/12/chevrolet-tahoe-hood-open-warning-on.html
These details will help.
Thanks.
1999 acura slx alarm
CAR ALARM ISSUES
Thanks.
2helpful
Alarm goes off for no reason
It can be any of the car door not got properly locked or the door is locked but the switch is not sensing the door locked.Open and close each door again properly.
Or else its problem with any of switch wiring getting in contact with alarm wiring causing it to happen.And last thing alarm connections needs to be inspected.Its getting short somewhere in between.
There are few helplinks with solutions,to troubleshoot these types of problems.I suggest going through these links.
Click the link below:------Volvo car alarm keeps going off for no reason http://technoanswers.blogspot.in/2012/07/volvo-car-alarm-keeps-going-off-for-no.html
------------------ Alarm keeps going OFF http://technoanswers.blogspot.in/2012/07/alarm-keeps-going-off.html
--------------2009 Toyota Camry: Hood Switch causing Alarm to go OFF? http://whatisbyme.blogspot.in/2012/04/2009-toyota-camry-hood-switch-causing.html
----------------Ford Pickup Alarm will not disengage? http://technoanswers.blogspot.com/2012/01/ford-pickup-alarm-will-not-disengage.html
------------Mitsubishi Diamante: Factory Security Alarm will not go Off http://www.howtorepairguide.com/2012/11/mitsubishi-diamante-factory-security.html
------------Toyota Avalon Factory Alarm will go off? http://repairhelpcenter.blogspot.com/2012/01/toyota-avalon-factory-alarm-will-go-off.html
----------Chevrolet Tahoe Hood open warning on dash and alarm sounds? http://schematicsdiagram.blogspot.com/2011/12/chevrolet-tahoe-hood-open-warning-on.html
-----------These details will help.Thanks.
Rechargeable remote central locking not working on mini cooper
Got a Mini Cooper JCW R53, changed the battery on the car and since then have not been able to lock/alarm the car with the remote key. The doors all work and boot with the key inserted into the drivers door. Any ideas what the cause is?
1helpful
Alarm set
this is a factory alarm, the problem is the alarm is active, you will need to use the door locks to turn alarm off, insert key in driversdoor and lock and then unlock door this will turn alarm off, if that doesnt work then use pass/side door, the lock has a built in switch that knows when the door is locked or opened, the driversdoor may have a bad switch so inturn the computer thinks the door was forced opened without key and it is turning alarm on, so again use the key to unlock door try the pass/side if driversdoor doesnt work. good day
2answers
Can you supply me with the colour code for the wiring on the alarm/central locking unit under the dash on a 2002 vw golf ? i am fitting a remote start alarm and when i remotely lock the doors i need the vw...
This is what I have for the Golf 2001:
' ITEM ' WIRE COLOR 'POL' WIRE LOCATION '
' 12V 'red '+ 'ignition harness '
' STARTER 'red/gray '+ 'ignition harness '
' IGNITION 'black '+ 'ignition harness '
' ACCESSORY 'black/red '+ 'ignition harness '
' POWER LOCK 'yellow/blue '- 'drivers door module *1 '
' POWER UNLOCK 'green/red *2 '- 'drivers door module *1 '
' LOCK MOTOR 'purple/yellow ' 'drivers door module *1 '
' UNLOCK MOTOR 'blue/yellow ' 'drivers door module *1 '
' DISARM DEFEAT 'pur/yel or blu/yel ' 'passengers door module *3 '
' PARKING LIGHTS + 'gry/red & gry/blk ' 'drivers kick panel '
' HEADLIGHTS 'yellow/red '+ 'headlight switch '
' DOOR TRIGGER 'blue/gray *4 '- 'comfort module *5 '
' DOME SUPERVISION 'blue/gray '- 'comfort module *5 '
' TRUNK/HATCH PIN 'brn/blk or brn/blu '- 'hatch light '
' HOOD PIN 'brown/red '- 'comfort module *5 '
'TRNK/HTCH RELEASE 'brown/black '- 'comfort module *5 '
' FCTRY ALARM ARM 'arms w/ lock ' ' '
' FCTRY ALRM DISARM 'disarms w/ unlock ' ' '
' TACHOMETER 'green/stripe ' 'ignition coil '
' SPEED SENSE ' ' ' '
' BRAKE WIRE 'red/black '+ 'drivers kick panel '
' HORN TRIGGER 'black/yellow '+ 'comfort module *5 '
' WIPERS 'grn/yel and green '+ 'wiper motor
*1 The drivers door module is located in the drivers door.
*2 A double pulse will unlock all doors and disarm the factory alarm.
*3 The passengers door module is located in the passengers door.
*4 This wire will read the dome light delay. The avoid the dome light delay, use the separate door trigger wires and diode isolate each one. They are brown/white and are all located in their own door at their own door module.
*5 The comfort module is the main control module located under the drivers side of the dash.
Use this diagram for the door trigger isolation: motorsport.com/images/install_notes/149.jpg
Use DIAGRAM A.
Hope this helps.
Interior lights stay and alarm goes off every time i lock it
Your car thinks a door is open , thus the light stays on. When you lock the doors with the remote it activates the alarm system. 10 sec later it senses that the a door is open and alarm sounds.
I have a 99 passat as well and I just went outside to see where the switch on the door is. Can't see one anywhere , it must be inside the door (part of the latch mechanism). I tried to arm the alarm system by locking the doors with the remote while the door was still open , sure enough the alarm went off about 15 secs later.
2helpful
2answers
My interior lights and door panel lights won't go out
One of the Dome/Interior Light Buttons is NOT WORKING at door
Top Mini Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Sam Akber
Sam Akber
Are you a Mini Expert? Answer questions, earn points and help others
