I accessed internet,connection settings, connection 1 - Wireless, change settings. I entered SSID as Waller and saved. After testing connection I got error message 51330. This states choose internet settings and then conform your connection. Please advise as to each step to correct this.
Judit,
We need ore information. Does the new modem you are now using have a built in "router"? If not, you had better reinstall your old router as when you just use a plain old modem from either cable or dsl your computer will be visible to the "low life hackers" out in the internet and it will be so easy to gain access to your computer and files it will and should scare you! Are you now using a router with your new modem? IF NOT, reinstall your old router with your new modem! The reason your not getting Netflix could be that the port settings on your old router will not be the same as the modem and if your new modem does have a built in router, you will need to "reconfigure" your Netflix with the new modem/router. The ports that your old router allowed access to Netflix will not be the same in the new router. You need to set this up yourself. Good luck.
