Motorcycles Logo
S
Steve Fuller Posted on Mar 22, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the Banjo bolts on the front of a 1989 Harley Davidson Sportster?
I am trying to Order a Brake Line for the front of a 1989 Sportster Motorcycle by Harley Davidson.I need to know what is the standard size Banjo bolts are? 10-mm or 7/16?
guy dubeau
Level 2:
Sergeant:
  • Expert 309 Answers
  • Posted on Mar 23, 2015
guy dubeau
Expert
Level 2:
Sergeant:
Answers
309
Questions
Helped
431428
Points
689
I believe it is 10 mm banjo on the sportster front brake system
5 Related Answers
Anonymous
  • 2336 Answers
  • Posted on Nov 10, 2008
SOURCE: replace rear brake pads
Remove right saddlebag, pull the two caliper mounting bolts and remove the caliper. Do not open bleeder or disconnect line. You will need to push a large screwdriver between the old pads before removing them in order to push the pucks back into the caliper or the new pads will not spread enough to reinstall. Then pull the two smaller bolts from the caliper and the pads will fall out. The pads are different for inside and outside, so pay attention, and remember, after reinstalling, before riding, be sure to pump brake pedal, and it may take a few stops before brakes stop as effectively as before.
Anonymous
  • 216 Answers
  • Posted on Nov 21, 2008
SOURCE: 1998 harley davidson softail custom primary cover bolt pattern
Are u asking for the torque sequence for the outer primary cover ?
Anonymous
  • 218 Answers
  • Posted on Jul 02, 2009
SOURCE: 2003 Harley Davidson Sportster 1200 Custom Tachometer kit
The only idea that i can come up with is that you dont have a good ground..or the guage was bad when you bought it..i hope this..Keith
Anonymous
  • 4565 Answers
  • Posted on Sep 24, 2009
SOURCE: Adjusting timing on Harley Davidson 1976 sportster
The advance timing should be 35° before Top Dead Center. This is how you find out which mark this is.
Get the rear wheel of the bike off the ground, remove the spark plugs, shift the bike into fourth gear, and remove the timing plug from the left engine case.
Now, take an ordinary PLASTIC DRINKING STRAW and insert it into the front spark plug hole. Do not use anything else or you stand a chance of it breaking and then you'll have to pull the head to get it out. The plastic straw will bend but not break.
Bump the rear wheel in the direction that it turns while riding down the road until the piston pushes the straw all the way up and just barely starts going back down. Look into the timing hole. You should see a timing mark. This is the Top Dead Center mark. Now, bump the rear wheel BACKWARDS until you see another mark. This should be the ADVANCED TIMING MARK. The piston should 7/16" down from top dead center.
On this model Sportster the timing is advanced by a mechanical advance mechanism. These units are notorious for wearing out and not contolling the timing very well. You must remove the breaker plate to inspect this mechanism. Mark the position of the plate before you remove it. If the pins and holes in the flyweights are worn, replace the unit. Replace it with a good needle bearing unit. Replace the points and reset the gap at 0.018 - 0.020".
Anonymous
  • 23 Answers
  • Posted on Apr 04, 2010
SOURCE: what type and size of socket is used to remove the
12 point 10mm
NNeed torque specs for 2010 harley ultara classic, front axle nut, front brake calipers, axle nut holder
Front Axle = 60 to 65 foot pounds
Front caliper banjo bolts = 17 to 19 foot pounds
Front Brake disk screws = 16 to 29 foot pounds
Front caliper mounting bolts = 28 to 38 foot pounds
Front axle holder nuts = 132 to 180 inch pounds
How do you replace the rear brake caliper on a 2006 hd sportster
Start with a suitable container placed under the rear caliper brake line banjo fitting to catch any brake fluid that may leak out. NEVER reuse brake fluid. Use only Dot 5 Brake Fluid in a 2006 XLH motorcycle. NEXT remove the banjo bolt and both washers to detach the rear brake line from the brake caliper and throw away the washers, remove the pad pin plug, unscrew and remove the brake pad pin, remove the brake pads, unscrew and remove the caliper bolt pin, slide the brake caliper on the rear bolt pin away from the brake disc as far as possible. THEN with an open end wrench unscrew the mounting bracket bolt pin from the caliper mounting bracket and lift the brake brake caliper straight up and away from the brake disc and the caliper bracket.
LUBRICATING THE REAR CALIPER BOLT PINS AND BOOTS
FIRST apply about 0.4 g of G40M BRAKE GREASE inside the caliper bushing boot and the caliper pin boot and inside the boot lip to prevent sticking between the boots and the bolt pins and insert the mounting bracket bolt pin into the caliper bushing boot.
INSTALLATION
Before installing the caliper ensure that the retainer bracket is properly installed on the mounting bracket, then apply a small amount of LOCTITE 272 THREADLOCKER to the threads of the mounting bracket bolt pin, place the rear caliper assembly onto the mounting bracket and using an open end wrench thread the mounting bracket bolt pin into the caliper mounting bracket and tighten it to 87-130 in-lbs (9.8-14.7 Nm). THEN apply a small amount of LOCTITE 272 THREADLOCKER to the threads of the caliper bolt pin, slide the caliper bolt pin through the front mounting hole in the caliper, carefully insert the bolt pin shaft into the caliper pin boot in the mounting bracket and screw the bolt pin into caliper and tighten it to 15-18 ft-lbs (20.4-24.6 Nm).
NOTE that the brake caliper housing has a positive stop for banjo fitting and so when tightening the banjo bolt into the brake caliper you will need to rotate the banjo fitting clockwise until it contacts the positive stop.
THEN position a new washer onto each side of the hydraulic brake line banjo fitting, insert the banjo bolt through the washers and fitting into the caliper housing and tighten it to 20-25 ft-lbs (27.1-33.9 Nm). THEN insert the brake pads into the caliper with the friction material on the pad towards the brake disc and with the curved portion of the pad fitting into the recessed area of the caliper and the brake pad front mounting tab fitting into its slot in the caliper mounting bracket. THEN press the brake pads tightly up and against the brake pad spring and install the brake pad pin but if the pin does not easily fit in ensure that you are suing the correct brake pads and not two identical pads, that the brake pad spring is oriented correctly, that the brake pad front mounting tabs are properly seated in the slots in the mounting bracket and that the brake pads are correctly pushed tight up against the brake pad spring BEFORE the brake pad pin is installed. AND THEN tighten the brake pad pin to 131-173 in-lbs (14.8-19.6 Nm). THEN install the brake pad pin plug and tighten it to 18-25 in-lbs (2.0-2.9 Nm). THEN with the rear brake master cylinder reservoir in a level position verify the brake fluid level in the reservoir. If necessary and with the bike upright and not resting on its jiffy stand remove the rear brake master cylinder reservoir cap and add sufficient new D.O.T. 5 BRAKE FLUID to the reservoir to cause the fluid to reach the upper fluid level mark, but do not exceed this mark. THEN verify the proper operation of the master cylinder relief port because a plugged or otherwise blocked relief port could cause the brakes to drag or stick on. Do this by pressing against the rear brake caliper to push the caliper piston back into its bore and push brake fluid back through the master cylinder and into the reservoir. THEN pump the brake pedal until the caliper piston pushes the brake pads out against the brake disc and firm pressure is returned to the brake system.THEN turn ignition switch ON and pump the brake pedal to verify correct operation of the brake lamp and test ride the motorcycle at low speed to safely test the brake system. If the brakes feel at all soft or spongy, bleed the system until you get a firm, hard pedal and avoid making hard stops for the first 100 miles (160 km) to allow the new pads to become conditioned to the brake disc.
Replace brake pads at any time the brake pad friction material on either the front or rear caliper is worn to 0.04 in. (1.02 mm) or less above the backing plate and always replace both pads in a caliper as a set.
The minimum brake disc thickness is stamped on the side of the disc and it must be replaced if and when it is badly scored or worn past the minimum thickness. Maximum brake disc lateral runout and warpage is 0.008 in. (0.2 mm) when measured near the outside diameter.
Aligning crankshaft marks
Camshaft timing procedure for 1982 harley davidson xlh 1000 cc
On the pinion gear there is a timing mark.
This mark will line up with the rear cylinder intake cam.
There are 3 marks on this cam.
One will line up with the mark on the pinion gear.
One other mark will line up with rear exhaust cam and the front mark on the rear intake cam will line up with a mark on the front cylinder intake cam.
The front intake cam also has a mark on it that will line up with the front exhaust cam.
http://www.downloadninjas.info/harley-davidson/1986-2003-harley-davidson-sportster-xl-xlh-service-manual/
http://www.downloadninjas.info/harley-davidson/2006-harley-davidson-sportster-xlh-service-manual/
1helpful
Brake fluid leak at front wheel fitting connector
If you mean at the "banjo" fitting where the line connects to the caliper, replace the "Banjo Bolt Sealing Washer" (2 per Banjo Fitting needed).
http://www.jpcycles.com/product/5000250
4helpful
Remove front forks off harley sportster
jack up bike so front wheel is off the ground remove brake cal. wire it up out of way.then remove front fender.loosen axle nut and remove and remove wheel then loosen pinch bolt on the thriple trees hang on to fork tubes they may slide out
How to change brake pads on a 2005 1200 Harley
there is 2 bolts on the caliper take them off and there are pad pins that need to be taken out.. inside the caliper there is a metal clip where the pad sits in.. put them in the same way they came out once you start its pretty self explainatory.. you should not have to blead them
Top Harley Davidson Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
ZJ Limited
ZJ Limited
Are you a Harley Davidson Expert? Answer questions, earn points and help others
