Question about Master Bilt Indoor Step In Cooler 70""W x 70""D x 92 and three quarters""H med
Hello my freezer is not very cold? is ther a problem with that? thank you
0 characters
1 Points
A lot of times, the reason ice production slows down is because the freezer isn't cold enough, usually because the freon level of the machine is low. Sounds weird, but even though the freezer is below 32 degrees F, which is freezing, the ice maker requires the temperature be below 10 to function properly. Another cause for the temperature not being cold enough is if the coils are dirty and ther machine is passing the heat to the machine itself
May 30, 2012 | Maytag MBF2556HEW / MBF2556HEB /...
I have a frigidaire model Frt18P5Aw1. The freezer is cold but the fridge is not. How do I fix?
there is a fan that blows the cold air from the freezer into the fridge. it's on the inside back of the freezer. it's either blocked in the freezer, in the fridge, or the motor is bad. remove any blockages in ther back of the freezer and feel if there is any air blowing into the fridge. if not, replace the fan motor. it's frigidaire manufacturers number 5303918549.
May 13, 2012 | Frigidaire Refrigerators
The Frige is not cool, only the Freezer is Cold.
Hello Chrofattah,
I understand that you are having a problem with you refrigerator not cooling but the freezer is working fine. I have wrote a tip that will show you how to fix this problem below is the link.
Freezer cold, Fridge Hot
Thank you for choosing
May 08, 2011 | Daewoo Refrigerators
Freezer box gets cold but fridge box stays warm.
Could be frost build up in the freezer compartment or a bad defroster,
Try running a diagnostic defrost cycle test and see what happens
Aug 17, 2009 | Refrigerators
Freezer not cold enough
make sure the condensor underneath is clean and if ther is a cond fan under ref make sure its running
Jul 05, 2009 | GE Refrigerators
Fridge side not getting cool, freezer works great
is the fan running in the freezer?.
is ther ice build up on the back wall of the freezer?
check fridge control, set midway, same with freezer control
Jul 01, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Fridge isn't cold
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
May 28, 2009 | Refrigerators
My kenmore refrigerator side by side
All the cooling takes place in the freezer and is blown over to the frig side so the frig side will start to warm up soon. Possible cause is the starting device to the compressor is faulty, compressor motor locked up or cold control faulty and not closing.
Feb 19, 2009 | Kenmore Refrigerators
Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Nov 10, 2008 | Frigidaire FRT15B3A Top Freezer...
Open Questions:
See all Master Bilt Indoor Step In Cooler 70""W x 70""D x Questions
Master Bilt Indoor Step In Cooler 70""W x 70""D x 92 and three quarters""H med Logo
37 people viewed this question
Top Master Bilt Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Master Bilt Refrigerator Expert? Answer questions, earn points and help others
