Electrical control to the wiper motor are also stuck in "on". It could be the switch, or the relay for power to the wiper motor or a short somewhere to a positive source of power. You should be able to remove the wire connection to the wiper motor, but protect it from shorting on any body metal (ground) or negative. by with tape on the end. Until you get the problem sorted out.
Pull the plug to the wiper motor. If it is corroded, clean it and the motor with battery cleaner. then add dielectric silicone to the end of the plug. If it stops, your done. If it starts again, replace the motor. The module is shorted out.
