Question about Kenmore Elite 21082
Kemore elite 21082
I think i have a bad control broad. when i plug the washer in it does nothing.
your can push all the control buttons and will not light up. If I push the
stop/ cancel botton , it stays on dilicate mode. I can push all the buttons and it will not change the setting and can not start it.
  • Mad2008 Mar 10, 2008
    I have a Kenmore Elite that was workinig perfectly until yesterday. Put in a load and cannot get it started. The buttons are all nonresponsive. Checked the outlet and there is power coming in. Any help is appreciated
  • Anonymous Mar 18, 2008
    The "controls locked" button is lit and the machine will not do
    anything. I've tried pushing all other buttons and have unplugged
    machine. Nothing is working. My model #44936.
  • 447 Answers
It certainly does sound like the main control, this is the most common part (electronically speaking) also there is the display board(s) directly behind the control panel. This PC relays user inputs to CCU (located on top of washer ---middle rear). I havent replaced a faulty display board yet out of the 50+ ive serviced. Doesnt mean its not bad. If you have any questions feel free....
Posted on Jan 16, 2008
Hello, Re: frontloading washer Model C45172 Our washer has been operating withiout hitch since purchase about five years ago, We love it. Today I tried to program it to do an extra rinse after wash...
For the Elite (HE) machines:
Press 'STOP' twice, press 'POWER', choose a wash cycle (such as 'NORMAL'), select wash options (water temp), press 'START' to finish the reset sequence.
Other Kemore electronic washers:
Unplug the machine for a minute, plug it in. Press 'PAUSE/CANCEL' twice.
Good luck from Detroit, MI.
Jun 12, 2011 | Kenmore Washing Machines
He3 washer will not start. The lights on the
you probably broke the door switch and the machine thinks the door is open. little piece on top of the lock catch. need to change the door switch
Feb 05, 2010 | Kenmore Elite 45986 Front Load Washer
Our Kemore Elite washer keeps stoping and displaying an error message of f11. We have to unplug it, or sometimes we can push a bunch of random buttons and that can unstick it! Its very frustrating......any...
1. Unplug washer or disconnect from power.
2. Check wire harness between drive motor and MCU. Between MCU and CCU. Check the motor and do a continuity test.
3. Plug in washer or reconnect power.
4. Check the MCU by looking for operations of the drive motor.
5. Check the drive motor for powered rotations.
6. Replace the MCU board.
Jan 30, 2010 | Kenmore Elite 45986 Front Load Washer
Washer will overfill on small load and large
If this happens only on small load cycle , then it can be a faulty timer board.
however check also the water level switch, when there is overfilling this part is always the first suspect.
May 21, 2009 | Kenmore Elite 21082
My kenmore elite oasis washer will not turn on. I
its the power button its a common prob use a soldering iron and switch it with the load sinal button this happpens as the washer alallows moisture to get on the board as its not protected it will save u a ton of money and anyone can do it
Apr 26, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite H3 control buttons - some work some don't
The diagnostic function will not help you if your user interface board (UIB) is acting up because to put into diagnostic you have to select drain spin, then the no spin option, and hit the prewash button 4 times.
It sounds like your UIB is the problem.
Jan 01, 2009 | Kenmore 42822 Front Load Washer
Water drainage problem
I continued to push the set delay and end of cycle buttons, twice. Then I pushed the jeans cycle button and let it run its course. After doing that twice, it drained the drum and I tried to start a new cycle for washing, which worked. Yea!
Mar 29, 2008 | Kenmore Elite 21082
Calypso kenmore elite - problems trying to wash a load
This is usually a symptom of a bad motor control board which located under the console. I had the same problem. You can open the console by removing the three screws in the back and lifting from the rear first. The console will pop off. In addition, if you look along washer top front edge in the seam there is a retaining clip about 2 inches in from each side. Using a putty knife, push in on each clip while lifting and the top should pop up. There will be a tech sheet affixed to the front wall of the washer between the wash tub and case. This tech sheet will give you all the guidance necessary on how to perform tests to prove whether or not the motor controller is at fault, or if the pump is at fault. I believe you may have a motor controller problem, though. Another possibility is getting something caught in the drain pump reservoir. This could binding the pump. Let me know if any of this is helpful to you.
Aug 16, 2007 | Kenmore Elite 21082
Washing Machines Logo
81 people viewed this question
Sal De
 Brian Main
Brian Main
