Question about Sony VAIO® VGN-S660P/B PC Notebook
Removing the hard drive to a Sony VAIO VGN-S660PNotebook?
I need to remove the hard drive, I have removed all the screws but the center of the back panel will not come loose, am i removing the wrong part, or do I need to remove the keyboard and remove it from that side?
  • Anonymous Mar 27, 2014
    I NEED TO CHANGE THE HARD DRIVE BUT, THE KEYBOARD WILL NOT COME OFF. I CAN'T FIND ANY MORE SCREWS. I AM WORKING ON A SONY VAIO VGN-N325E. THANKS
    Scholar:
  • 71 Answers
On this line of Sony models replacing the hard drive is a pain because the computer must be taken completely apart to get to the hard drive. It is located under the palm rest. I looked up the Sony manual for this model and it does not show how to replace the hard drive -- meaning it should only be done by a trained tech.
You'll have to remove all the screws from the bottom and underneath the keyboard. Carefully detach the keyboard and set it aside. Once all the screws are remove from the laptop you should be able to separate the top of the casing from the bottom, this usually requires a small amount of force but too much force will crack the plastic! Underneath you will find the hard drive cage.
Also, some laptop vendors like to pull the 'hidden screw' trick! There may be a screw underneath the CD-rom drive so that may have to be removed or under some of the rubber feat on the laptop.
I couldn't find a photos or manuals that show how to do this, but these guys say they have a manual for a small fee. http://www.9manuals.com/Vaio2.htm
They want $5.99 for the manual but that is much cheaper than paying a technician to do it for you.
Good luck and be careful!
Posted on Nov 14, 2007
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
http://www.fonerbooks.com/laptop_1.htm
http://www.youtube.com/watch?v=rg_GvaMunas
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
http://www.ebay.com.au/itm/New-500GB-Sata-Hard-Disk-Hdd-for-Sony-VAIO-PCG-3H2L-VGN-P530H-VGN-SR410J-B-/190882270487?pt=US_Internal_Hard_Disk_Drives&hash=item2c71784d17
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
Remove keyboard 646125-001
  1. Prior to replacing your replacement keyboard for sony vaio vgn-fe880e/h, make sure to remove the keyboard and disconnect the ac adapter from your laptop.
  2. The first step to replacing your laptop keyboard is to remove the screws from the back of your vaio vgn-fe880e/h. Sometimes your laptop will have a picture of a keyboard next to the screws that need to be removed. Otherwise, see your laptop manual for details.
  3. Above the laptop keyboard for sony vaio vgn-fe880e/h, you have a cover panel. If required, remove this part to easily access your keyboard. If you have screws above your keyboard, remove those screws.
  4. Now that you have removed all the screws, you are ready to remove and then replace your new laptop keyboard.
  5. To remove the vaio vgn-fe880e/h Keyboard, take a thin object and pry the keyboard out between the keyboard and motherboard. Be careful when removing the keyboard.
  6. Now that your keyboard is loose, simply disconnect your keyboard. In order to disconnect the keyboard, pay attention to the keyboard connector and connector cable. Unlock the connector cable device and remove your laptop keyboard. Your sony vaio vgn-fe880e/h connector cable should be easy to remove by simply sliding it out.
  7. Now that your keyboard has been removed, get ready to install your new laptop keyboard. Look at the back of the keyboard. If you see any screw holes, you will have a good idea of where to place the screws back in at the bottom of the laptop.
  8. Connect your laptop keyboard for sony vaio vgn-fe880e/h to the motherboard keyboard connection slot. Secure the keyboard cable. Now turn your keyboard in place, and align the grooves on the bottom of your keyboard with your palmrest or plastic bezel. Secure your laptop keyboard in place, make sure it fits properly and is snug. Now simply place the screws back in place.
Nov 30, 2012 | HP 646125-001 - Keyboard Tm - Us
How to remove hard drive from Sony Vaio Laptop VGN - NR110E?
On the bottom of the laptop there should be a cover for a quare or rectangle shaped slot, most likely with two screws in it. Unscrew these, and the hard drive bay will come loose. Just unscrew it from the bay and it should be free.
May 02, 2011 | Sony Vaio VGN-NR110E/S Notebook
How do you physically open the laptop to remove the hard drive?
Most laptops will have one or two screws underneath to access the hard drive - it's basically a like a door. In most cases, there is a little picture next to the screws to remove and it looks like a hard drive picture. Unscrew the screws and you just need to pull it out - be careful - you may need to remove additional screws inside.
Jan 17, 2011 | Sony VAIO VGN-T170P/L Notebook
How to change hard drive on Sony VGN-N130G?
I need the model number printed on the front of your case, VGN-N130G does not exsist on the sony web support page. http://support.vaio.sony.eu/computing/vaio/index.aspx?l=en_GB
Usually there is a cover under your laptop that is marked.
Remove 1 or 2 screws and your harddrive should just slide out.
Jul 14, 2010 | Sony VAIO VGN-N130G/W Notebook
Need service manual or instructions on replacing hard drive on a Sony Viao VGN-ns135e or Sony VGN-NS100 Series Laptop
The hard drive is inside of the laptop and not accessible from the outside. The way to get to the hard drive is to take out all the screws from the bottom of the laptop, take the keyboard out and there may be some screws there that need to be removed. The dvd drive needs to come out and where the dvd drive normally is, check for screws there.
At this point you can remove the top cover assembly and you will see the hard drive. Remove the screws that are holding the hard drive in place and then it will come out.
Nov 30, 2009 | Sony VAIO VGN-NS135E/S Notebook PC
Replacing Hard Drive in a Sony VAIO SZ330P/B
Turn your Vaio upside down and look for an easy access panel or release lever to remove the hard drive carriage. You will probably need a small Philip's screw driver to remove the carriage, but I don't think you need to remove the keyboard.
Aug 10, 2008 | Sony VAIO VGN-SZ330P/B Notebook
Replacement of hard disk in Vaio VGN-A150
Well, it's not good news. Official word from Sony:
Knowledge Article C309925...
Can the notebook hard drive be upgraded or replaced
Hard drive upgrades in the notebook computer are not supported.
NOTES:
* Some notebook computer have instructions for warranty replacement of the hard drive by an end user.
* Although third-party upgrades may be available for some models, they are not supported.
* If the hard drive needs service, repair should be done by an authorized Sony service center.
* External hard drives may be attached if the appropriate connections are available.
This basically means complete disassembly of the laptop is required to get at the hard drive. Not that it can't be done. Just that it'll be a major pain in the .... you know.
There is no hidden key!
Jul 24, 2008 | Sony VAIO VGN-A150 Notebook
Vaio VGN-TXN25N, need to remove hard drive
Usually the laptop hard disk is only reside in the side of the laptop. Sometime you need to remove the small cover first before you can see the screw. Look in the right side of the laptop or in the back but there is also laptop model that the hard disk is below of the keyboard.
Apr 23, 2008 | Sony VAIO VGN-TXN25N/B PC Notebook
How can I remove the hard drive from a Sony VAIO PCG-F305?
Remove the keyboard also,there's usually some more screws under the keyboard.
Oct 17, 2007 | Sony VAIO VGN-S460 Notebook
Sony VAIO® VGN-S660P/B PC Notebook Logo
210 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
