Question about Miscellaneous
How do i reattach the fixture on the liftgate of my 2007 Chevy Tahoe
Recently I noticed that the fixture that holds the lights for the license plate on the lift gate of my 2007 Chevy Tahoe is loose. Can anyone tell me how to secure it back in place?
    Top Expert:
  • Miscellaneous Master
  • 47,657 Answers
Try removing the trim from inside the boot and tighten the nuts up on the bolts that hold that section
Posted on Mar 22, 2015
  • James Clubb Apr 04, 2015
    How do I remove the inside trim?
2007 chevy equinox license plate light won't work after bulb and fuse replacement
Do the park lamps work ? license plate lights get power from same fuse ! Check ground wire ! use a volt meter an do voltage drop test ! Voltage Drop Testing The fuse for the license plate lights is in the under hood fuse box -engine compartment ! fuse #12 RT PRK LAMP 10Amp .
May 23, 2015 | 2007 Chevrolet Chevrolet Equinox LT
1996 Chevy Tahoe liftgate not opening
You have likely got broken wires where they come out of the cab and into the liftgate. pull back the rubber and check them at that point.
Mar 27, 2015 | 1996 Chevrolet Tahoe
How do I replace the rear license plate bulb on a 2011 Nissan quest ?
usually on most vehicles the fixture that holds the bulb pops out and you can access the bulb. If yours doesn't pop out then you will need to remove the panel on the liftgate door to get to the bulb.
May 18, 2014 | 2005 Nissan Quest
License plate light will not stay on this for a 2007 chevy tahoe,what do i have to disassemble to check wiring
If you notice should be a couple small screws to remove lens to get to bulb. A lot of times it just a loose bulb or the prongs on end of bulb that hits the copper connection. First take bulb out, replace it, even though it works, but new one would have nice new connection, and before putting it in, spray inside where bulb goes with electrical cleaner can get at any auto supply, then put in. Should work. On a 2007, it is unlikely there is a ground problem, but if so, after trying this, get back to me and I will tell you how to check wires and what to do. Thanks Mike
Oct 05, 2011 | 2007 Chevrolet Tahoe
License plate light do not stay on,the bulbs are not blown,the vehicle in qusetion is a 2007 chevy tahoe
If you notice should be a couple small screws to remove lens to get to bulb. A lot of times it just a loose bulb or the prongs on end of bulb that hits the copper connection. First take bulb out, replace it, even though it works, but new one would have nice new connection, and before putting it in, spray inside where bulb goes with electrical cleaner can get at any auto supply, then put in. Should work. On a 2007, it is unlikely there is a ground problem, but if so, after trying this, get back to me and I will tell you how to check wires and what to do. NOW understand sometime even though the bulb is not blown it is not getting a good connection from bottom of bulb to copper prongs on female side insert. I do not thing it is wiring as said earlier.
Mike
Where is the fuse for the license plate bulbs of a 2002 Chevy Tahoe
the headlamp switch controls the license light. the filament in all bulbs react as a fuse when shorted out. replace the bulb
Feb 20, 2010 | 2002 Chevrolet Tahoe
How do i replace the license plate lights on my 1990 honda accord. i can't get the bulb out of the socket
You should have two license plate lights, right above the license plate. If you remove the two screws that hold the one you want to change in, the entire fixture will drop down(best to do this with the trunk open). Remove the metal clip plate that covers the bulb. The bulb SHOULD simply pull directly out.
Hope this helps you.
Oct 21, 2009 | 1990 Honda Accord
Miscellaneous Logo
474 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
Dan Grod
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
