Question about K40 2000P Radar Detector
One of the led lights keep on blinking on and off
I just installed the 2000 and one of the lights continue to blink on and off
0 characters
1 Points
Whistler 2270
Double check all the connections that plug into the display unit. Make sure that the positive and negative connections are secure- especially the ground. If this doesn't help, call Whistler at 800-531-0004 for more options.
Aug 18, 2014 | Whistler Radar Detectors
Phone keeps blinking while in charger?
Flashing light usually means faulty battery. Replacement may be the only answer.
Oct 24, 2013 | UNIDEN AMERICA CORP Uniden BC-246T Compact...
Hey I installed led indicators to my wr450 and they don't flash the light is just staying on like a normal light bulb. what could I do to fix this problem?
you either need to change out or wire in a electronic flasher relay... the auto parts store has them for about $12 the L.E.D.'s use less voltage and your stock flasher doesn't see them... I had to do the same thing on several of my motorcycles
Aug 30, 2013 | Radar Detectors
I need to know how to turn off the top two perascopes on a xtr 255
See the steps below from the XTR-255 owner's manual:
Option Select Mode (XTR-255/260/330)
Press the Menu button to enter Option Select
Mode. Each press of the Menu button changes
to the next selectable feature.
The Dark (D) button and the Quiet (Q) button
turns the feature ON/OFF or Blinking. The decimal
point illumination indicates whether a feature
is on or off. A button must be pressed within
20 seconds or Option Select Mode will automatically
be exited.
The fisrt option is VG-2, the second option is the Periscops (which you want to turn off) and hte third is the blue LEDs in the display.
Nov 06, 2010 | Whistler XTR-520 Radar Detector
Blue lights on top of the unit won't turn off
Go into options mode and select LED BLNK to Blinking. This will return the lights to normal.
Jul 13, 2010 | Whistler XTR695 Radar Detector
Will not power on-- batteries are new- if pwr
I was using one of these for the last 8 months, and mine did the same thing, I would push power and the unit will just blink the lights then shut off, But if I hold the power button the light will stay on until the button was released, so I contacted Solo Tech support and they told me the system control board was bad, and in order to get a new board I had to be an authorized servicer for then, I found the board online and the price for the board exceded the price I paid for it. So i deemed it necessary to just purchase a new Scanner....
Dec 27, 2009 | Escort Solo S2 Radar Detector
19375512B92 ford Explorer XLT Title 0126902Q
Mar 18, 2009 | Radar Detectors
I have a Solo Radar Detector and all of a sudden when you insert the batteries and turn it on, it goes through the motions of turning on, then when done, the solid red light just blinks. I don't have a...
Well first off in doing so removing the batterys before you powered it off its stuck in some kind of error mode. Try putting the batteries in, holding the power button down for a few seconds and see if the light stops blinking.
Second Idea if you have a local radio shack they have replacment power cords for radar detectors there about 10 dollars. I had to go buy one for mine. After powering it up with that Id say it should work fine.
Feb 22, 2009 | Escort Passport 8500 Radar Detector
LED Display gives you your display visual alerts, signal strength, and operation mode. Here is an attached link for the manual.....
But to answer your question here is what the difference between the green light and the red light are:
1. X-Band Signal Indicator—A green LED lights and blinks to
indicate the presence of an X-band radar signal. The blink rate
increases as the radar source gets closer. A distinct audio alert is
also heard.
2. K-Band Indicator— An amber (orange) LED lights and blinks to
indicate the presence of a K-band radar. The blink rate increases as
the radar source gets closer. A distinct audio alert is also heard.
3. Ka-SuperWideband Signal Indicator— A yellow LED lights and
blinks to indicate the presence of a Ka-SuperWideband radar
signal. The blink rate increases as the radar source gets closer. A
4. Laser Signal Indicator— A red LED under L lights and blinks to
indicate the presence of a laser signal. A distinct audio alert is also
5. SWS Signal Indicator— When an early warning hazard or
informational signal is detected, the yellow SWS LED begins to
blink and the amber K-band LED lights. A distinct audio alert is
also heard.
6. Power-On Indicator— A green LED under P lights to indicate
power is being supplied to the unit and the unit is turned on.
7. LED Signal Strength Meter—Four LEDs give an accurate visual
indication of the strength of radar or laser signals.
8. City Mode Indicator—A green LED under C lights to indicate
that you selected City Mode.
9. Auto Mute Indicator— A red LED under M lights to indicate that
you selected the Auto Mute feature.
Please make sure you give me a rating and I hope this helps,
Oct 18, 2008 | Uniden LRD6399SWS Radar Detector
Car problem
rover vitesse has shut down all ignition lights no power to starter
Dec 10, 2007 | Cobra XRS-757 Radar Detector
K40 2000P Radar Detector Logo
60 people viewed this question
Top K40 Radar Detectors Experts
John Nolan
Are you a K40 Radar Detector Expert? Answer questions, earn points and help others
