Question about Sharp XR-10X Multimedia Projector
Projector unit will not turn on, it just shut down on me when i was watching. where is themal fuse and how do you take off cover. thank you
    Problem Solver:
  • 9 Answers
It's likely you have a badly clogged air filter which will greatly shorten the life of the lamp and projector. It MUST be kept clean! Your instruction maunual will show you where it is located. If this does not resolve it, you likely need a new lamp.
Posted on Jan 08, 2008
We were watching a show and the projector shut off. Does not seem to power on at all. Seemed hot to the touch. Have tried other plugs.
sounds like the power fuse may have blown, or electronic failure, overtemperature switch/fuse may have gone open circuit.
Are the air vents free of blockages etc.
Is the cover on the lamp and filter tight
Mar 18, 2011 | Sanyo PLV-Z3000 LCD Projector
When we turn on the projector to watch tv there purple spots what to do Thanks Sue
if this is an lcd projector, you can try blowing the area out where the lcd come out of the engine, if it is only dust particles you should see results, you may have to repeat the process to get it perfect, and use de-ionized air if available, this cuts down on static. Next, if that didn't work, your polarizers are probably burnt due to repeatedly shutting the projector down incorrectly. The unit is pretty much shot at this point. the cost of repairs likely will exceed what you paid for it.
May 21, 2010 | 3M MP 8640 Multimedia Projector
Projector turns on the power light flashing and lamp light solid
Here's the fix: Take off the top cover of the projector. Unplug the wire leading from the two fans in the back of the unit to one of the circuit boards in front of you. Just trace one wire from fan to board. Unplug at board. Turn unit on and it will again turn on, show HP splash screen and then shut down, like it should, because the fans are now disabled. After it completly shuts down, plug the fan wire back into the board. Turn the unit back on and, presto, its working again. It will not turn off.
Try it!
Jun 12, 2009 | HP Digital Projector Vp6120 Multimedia...
No power indications
Fuse problem or power supply.
If it's the lamp, you'll still get a standby light.
Check also the ventilation, that might caused it to shutdown.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 09, 2008 | Sharp XR-11XC Multimedia Projector
This model projector is very sensitive to internal heat. I f by some reason the projector was abruptly powered down without the use of its normal procedure, in other words, unpluging cord from wall while on or power outage in premises, then the heat remains trapped and the sensors overheat and subsequently shuts down the unit. Now, although, once the sensors cool down it should reinstate operation some sensors become permanently damaged due to the extreme heat. In this case without having more facts, i believe it is the cause. I recommend a free check up to your nearest shop, most shops will offer free check ups.
Jun 07, 2008 | InFocus IN72 Multimedia Projector
Hi there
Replacing the lamp won't make any difference at all.
If you have checked the fuse on the Powersupply Board and it tested ok , then the whole Board will need replacement.
Apr 29, 2008 | Sony LMP-C121 Projector Lamp for VPL-CS3,...
My Panny AE700U shut down & won't restart
HI there
This is a faulty Mainboard that will need either repair or replacement.
If a Projector starts playing on and off tricks I have found it to be 99% of the time a faulty Mainboard.
Apr 13, 2008 | Panasonic PT-AE700U Multimedia Projector
PT-LB20VU unit won't power on
check for the following:-.
1--the power cord may be disconnected.
2--main power switch is turned off.
3---no voltage(electricity)in wall outlet.
4-the lamp cover has not securely closed.
5--check for blown power fuse and change it with the same rate.
6--defective power supply unit.---.
Jan 21, 2008 | Panasonic PT-LB20NTU Multimedia Projector
Remove the six screws from the bottom and 2 screws in the back that hold on the top cover. Once you have the top cover removed you will see a small round red button on the front of the unit. Press this button in; it should not pop back out. Put cover back on and plug it in.
Feb 20, 2007 | Sharp XR-11XC Multimedia Projector
Sharp XR-10X Multimedia Projector Logo
46 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
