with cordless phones the problem is that the hand sets have to be recognized by the base station ( paired) and unless you have the exact hand piece make and model this pairing and recognition will not happen
if you can get 2nd hand units for the 3325 base then the base will accept them ( any number of additions ) but if the hand piece is different it will not work
you you need extra hand pieces then it may be best to consider a new system where you can buy extra phones and chargers
Simple answer yes they are compatable I just did it as I could not find any CD445 handsets.The manuals are downloadable from Phillips just search for CD445 or CD245 manual.Just press speaker button on 445 base for 5 seconds untill it beeps twice,then on new 245 handset menu/ register enter default code 0000 and bingo its live. Oddly the newer handset bases are 9v and not compatable with 445 bases which are 6v and have different contacts so you cant sit your 245 in the old base.My new 245 came with a new base anyway so no problem.
there is a problem with the Base unit (Charger), repair man said that the main IC should b changed which is too costy, better to buy another set. The handset of the faulty unit can be paired with the new set. in short the handset shows what it receives from the base (charger) so it has no fault and may be used with another set
sir i have given a complete procedure in the caht session u had with me but there was no response suddenly pls check that procedure to solve your problem and rate my chat session
thank you
To turn off the tones whch sound whenever you press a key do the following:
1. Press the MODE button until the music note icon on the display flashes.
2. Press UP or DOWN to select the desired setting (either On or Off).
3. Press MODE again to save or simply wait 15 seconds.
