Question about HP iPAQ H1910 Pocket PC
H1910 I have a 1910 that randomly shuts off. Sometimes it is within minutes, other times it is after only seconds. I heard that it can be caused by bad battery connections, so I removed that battery, cleaned the contacts and the problem persisted. I am wondering if it is due to the battery (a cheap new e-bay battery I bought) or if it is something else. I have dropped my pda a couple times but I don't see any loose parts when I take it all the way apart.Any ideas?
Re: h1910
Posted on Jun 26, 2008
0 characters
3 Points
Blackberry just randomly shuts off
check your battery terminal. I had this same problem right out of the box. it would only stay on for 15secs shut down and continue to cycle. turns out one of the 4 prongs wasnt connecting right with the battery. I could clearly see one was shorter than the others.
The phone would only work if connected to the computer.
Are you within your 30days? or 1yr manfacture warranty? or 90 days if it refurb (ATT)(anyway)
Jul 09, 2009 | RIM BlackBerry Curve 8310 Smartphone
My Tungsten T3, from time to time, turns itself off within 2-10 seconds after I turn it on. The delay is random; the problem is random (it doesn't do it for weeks, and then it apparently goes into a snit...
Issue rather seems software related, if Battery issue usually comes up with low battery alert.
A full (Hard) reset can be a good solution to be sure if its Software related. If you do so make sure you have backup of all your data as full reset will set everything to factory default and will erase the personal data
Good Luck
Mar 16, 2009 | Palm Tungsten T3 Handheld
Shutting on and off
If your battery is fairly new, then you have a technical problem as the unit is resetting. A faulty battery can cause this but not at random. If under warranty, have it seen to.
Jan 08, 2009 | Sony Ericsson G900 Smartphone
Screen on Treo 755 fades after runnin video for few minutes
take the phone and have it diagnosed
Sep 14, 2008 | PDAs
Blackberry 8310
Are you sure it is shutting of? It might just be locking, if the screen goes blank after 10 minutes try pressing the * key and call key and it should unlock the screen.
May 23, 2008 | RIM BlackBerry Curve 8310 Smartphone
Htc p3300 problem
I have the same problem with my p3300, i tried to flash a new rom from xda developers, but nothing..
i tried to change the battery, again the same problem...
could somone help us!?
Apr 19, 2008 | HTC P3300 Smartphone
MicroSD sometimes being recognized
The problem is more likely a bad memory card. Try formating the card , if there is still problem , put a new card . It should be ok.
If still no go .... its time update the firmware..and if that charm doesnot work... its time to toss it out
Apr 11, 2008 | Motorola Mobility A1200
Treo 755p (Sprint) Will not pull power from battery or AC,/?St=56,E=0000000000825376672,K=2082,Sxi=19,Case=Obj(30029)
Depending on how old or new (maybe a bad battery from factory), this is the only thing I found related -
My battery loses its charge very quickly
Like all Lithium Ion batteries, the battery in your device will eventually wear out. If you charge your device fully but it loses power after a few hours (or sooner), it may be time to replace the internal battery. Arrange for a repair.
For best results, don't let your battery fully drain before recharging. Lithium Ion batteries last longer if you "top them off" frequently.
Jan 06, 2008 | Palm Treo 755p Smartphone
MDA sound problem
1. plug in handsfree
2. pull handsfree ^up^ (holding it hard), and at the same time
3. slowly pull out
Oct 12, 2007 | T-Mobile MDA
HP iPAQ H1910 Pocket PC Logo
77 people viewed this question
Top HP PDAs Experts
David Payne
David Payne
Bob S
Level 1 Expert
Are you a HP PDA Expert? Answer questions, earn points and help others
