The air damper flow control? to far open some are manually set some automatically set? other issues the thermistors are bad? the cold control thermostat is set to high or bad? check all with a multi meter. for continuity, how is the freezer not all frozen too? fan blowing? a bad defrost terminator will cause bad ice build up everywhere eventaully
SOURCE: Freezer not freezing
Check the back wall of the freezer section for signs of frost build-up. If the freezer coil is frozen from a fault in the defrost system your refrigerator will be the first to show signs of not cooling.
SOURCE: fridge freezing everything
If your fridge is freezing to much put the thermistor closer to the fins (it will make it colder so it shuts off sooner)
SOURCE: my daughter's mini fridge has a freezer
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Testimonial: "We're gonna try the steps you suggested right now. I figured it was something along those lines, but I wasn't entirely sure. Thanks for the help!!"
SOURCE: bottom of fridge section freezing, rest fine.
maybe fridge fan not working when door is closed could also be iced up air ducts between fridge and freezer
SOURCE: Miela fridge freezer freezes food in the fridge
Most likely reason is fridge evaporator sensor faulty. The sensor is screwed to the back wall of the fridge behind bracket next to light and has a green band near the end . The sensor come as a repair kit (part no. 7323301). Just follow instructions in the packet.It is quite straight forward
