Question about JVC KD-S570 CD Player
Install in 2000 Neon?
I can't figure out which wires from my JVC KD-S590 to hook up to my Neon's stereo system. Can you help?
  • 709 Answers
Hi Siriusearl,
If the original connector and wires are not messed up and your doing a direct replacement of your Factory Radio, your in good shape. Go to Best buy and get you and adpater to go from 2000 neon. If you have the one that direct couples and leaves wires to terminate to the JVC, then you will have to hook up by standard hookup colors. And it should be color to color from JVC to the Adapter cable. If your still have trouble, leave another comment here and I will get an alert to check in on you.
Posted on Nov 13, 2007
Just got a used boat with a JVC KD S590 stereo and a JVC KS AX302 amp. The stereo works fine with the in boat speakers but the tower speakers do not work, I checked them both on another system and they...
take a digital volt meter and check the power cable and ground on the amp to see if you are getting any power . should read 12.5 or more if no power then check fuses and the ground connection
if you have power then replace the equipment that not working
Oct 29, 2010 | Car Audio & Video
Cannot find way to change time setting after DST began today. no manual jvc kd-s590
Press and hold SEL (Select) and Adjust with volume up/down and move from hours to mins with next track/last track
HTH :)
Just found a manual at
http://www.jvc.ca/en/consumer/archived-product-detail.asp?model=KD-S590
looks like im close, but have no model to test with sorry
Mar 15, 2010 | JVC KD-S590 CD Player
Jvc kd-s590, installing in other car and only the att (red) light comes on no display or sound. tried resetting, fuse is good. that's it.
sounds like only the constant(yellow) wire has power. you need to make sure that the switched wire(red) has power as well. good way to trouble shoot, is to hook the red to the yellow to see if it powers up then, if so you know the radio is ok, you just need to find a better power source for the red wire. hope this helps.
Aug 18, 2009 | JVC KD-S570 CD Player
Front speakers do not work
try to check the transistor and resistor
Apr 26, 2009 | JVC KD-S590 CD Player
How to instaled my jvc kd-s590 to astro chevy 1993
Here you go second to last page showes you how to hook up.
http://resources.jvc.com/Resources/00/00/97/49767ien.pdf
Good Luck and please Rate Fixya!
Mar 15, 2009 | JVC KD-S570 CD Player
I need to no what the wire colors mean on my head unit
hope this helps
Feb 17, 2009 | JVC KD-S590 CD Player
JVC kd-s590
you need to have whoever installed the unit connect the YELLOW (memory) wire on the back to a constant 12 volt power source. It is hooked up right now to only have power when the key is on. this is why when you turn off the key, you loose memory.
what kind of car is this in... I can tell you what wire goes to what color if you cant figure it out.
Jan 12, 2009 | JVC KD-S570 CD Player
Settings
hola, nesesito ayuda para poner la hora a mi estereo jvc kd-g320 ya le busque por todos lados y no le encuentro.. si alguien puede ayudarme, se lo agradecere... gracias.
Feb 04, 2008 | JVC KD-G320 CD Player
JVC KD-S570 CD Player Logo
129 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
