Its a inverter 1100w model. i know they do same one in sears but cant afford to spend 500 plus for a new one
SOURCE: microwave light door turn table works but does not heat up food
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: Panasonic Model No. NN-S933BF Microwave Oven
could it be that i didn't follow the manuel because i got it second hand or is it because something is wrong with it,and i have to get it fixed.
SOURCE: Panasonic - NN-T993SF 1350 watts microwave
Sorry this is something you wont fix at home I couldent even do this one.This is a nice unit depending on the cost this one I think is worth the repair bill , Good luck DFD please rate me TK U
SOURCE: The oven stops partway into the set time, and doesn't heat.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other. Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these. You can find an authorized Panasonic servicer here. In Canada, you can find an authorized Panasonic servicer here. We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
SOURCE: my panasonic inverter microwave model no NN-T523M
You can find Panasonic owner's manuals here.
The
first thing I would suggest is a hard
reset. Unplug the unit for a
minute or so. Then plug it back in, set the clock and try again.
If that doesn't work,
leave it unplugged for about 5 minutes.
See if this describes
what's happening:
If so, see
http://207.234.249.73/mwd/safety.txt
http://207.234.249.73/mwd/disassembly.txt
http://207.234.249.73/mwd/doorsw.txt
Otherwise, if
the digital programmer circuit / controller does not get a feedback
signal from the inverter for a period of 3 seconds, the controller will
stop the cook cycle.
If
it stops after 7 seconds, it has a problem with the inverter.
It may be a loose connection in the wiring between the
inverter, magnetron, and/or control board, or maybe one of
those
components has failed.
Due to the lethal
If you decide to replace your inverter, you can order Panasonic parts from
Encompass here
or you can call them toll-free at
866-779-5835.
We're
