Question about Plumbing
How to wire disconnect switch for marathon electric 115 volt 1 phase motor
    Master:
  • 996 Answers
How to wire disconnect switch for marathon electri - 25596087-jzfrizbeonx35ny4gh1lem4b-4-0.jpg
Posted on Mar 21, 2015
mydogisk
  • 50 Answers
SOURCE: cutler hammer a10ano series a-1 contactor
There should be 2 contactors for forward and reverse. you have to wire them so that the power coming in will switch 2 opposite phases to reverse.
Posted on Apr 10, 2009
SOURCE: have 2 black wires n
The TWO Black Wires are Phase and neutral and it's irrelevant which way they go on the motor, the Other is the earth and that MUST connect to the case.
Black, L1 & L2 the other green EARTH.
115 or 120 doesn't matter
Posted on Aug 09, 2010
john224
  • 1378 Answers
SOURCE: shop idiot took motor appart unhooked all internal
Please contact me thru www.arrowmotor.net using the contact form and include the model number of the motor and we can get you the exact diagram for the motor in question.
Posted on Aug 09, 2009
  • 497 Answers
SOURCE: need help wiring reverisable 115 volt motor
the only way to reverse the movement it to rotate the stator.
Posted on Oct 06, 2009
  • 832 Answers
SOURCE: Sears 1/2 hp shallow well pump wiring for 230 volts
You don't need to touch the pressure switch when you
convert it to 220. By the way, is it possible for you to send the me the brand of the electric motor driving it
so I can help you. Send you e-mail asap. Thanks and God Bless U.
Posted on Oct 27, 2009
I have a 1 1/2 hp 230/110 marathon single phase motor controlled by forward reversing starters with 24 volt controlled. How do I wire this motor up for for/rev ???
You need to determine at which voltage you will run this motor. A motor starter mechanically and electrically interlocked for F & R. with 24v transformer, a SS and FR station. This is expensive but sweet, needs room for this equipment.
The easy budget is by using a drum switch.
The motor nameplate or splice box cover will hand the info on how to connect the motor for either voltage and for CW and CCW rotation.
The magnetic motor starter also will include a wiring diagram.
Nov 04, 2017 | HP Air Tools & Compressors
NEED TO KNOW HOW TO REVERSE DIRECTION OF 1/3 HORSE CENTURY 115 VOLT MOTOR
Has someone torn it apart to rebuild it? This motor is wired to only run one direction.
With three phase electrical like large commercial applications you can change direction by altering the electrical hookup but not on a 115v unless there is much deeper issues internally.
Aug 25, 2016 | Pool & Spa
Wire 230 volt air compressor wiring diagrams
On 230 volts you have 3 wires 2 are 115 volt and the third wire is ground. As long as you hook the ground wires together correctly the other wires don't matter. Usually the ground wire is either white or green. The black wires are hot (115 volts).
Feb 11, 2014 | Air Tools & Compressors
Electrical diagram for contactor (240 v/1 phase/24 v coil)
How to connect motor 1 phase with mcb , contactor , timer ,switch selector on off on , and lamp indicator
Feb 17, 2012 | Omega Trane Furnace Draft Inducer Blower...
I want to reverse rotation on my A.O. Smith 120/230 volt single phase 1.5 HP motor. Catalog number B762
I believe all you have to do is swap your two hot wires,that works for 3-phase but not sure on single phase
Oct 07, 2010 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Have 2 black wires n 1 green is this 115 0r 220 volts n where do wires go l1 or l2
Aug 09, 2010 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
I wish to rewire a single phase electric motor with compositor's that is currently setup for 230 VAC to 115 VAC. The motor is a Ingersoll-Rand Air Compressor motor with the following nomenclacher. Single...
The motor itself should have a sticker which describes the wiring for 115. It is a small change involving a single wire moving from one pole to another inside the motor starter cap (the bump on the motor itself).
Aug 26, 2009 | Air Tools & Compressors
Plumbing Logo
186 people viewed this question
Top Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
