Question about Kenmore 24 in. 15932 Built-in Dishwasher
Fills with water then nothing happens (no noise). Will not drain either, it is less than 2 years old.
The dishwasher fills no problem, but when the lights on the control panel go to wash nothing happens. No noise at all. Also, when I hit the cancel/drain button it does not drain. After a little bit the light goes out. I looked underneath and there is no signs of leaks and it is very clean. It is a Kenmore Ultra wash and it is under 2 years old. Any advice would be appreciated (is there a fuse that could be the issue?).
Thank you.
  • 3 Answers
Check your curcit board, could take care of the problem
Posted on Jan 04, 2008
Dish water is not working. Water fills but no noice after that.
it's obviously sounds like your pump has gone, but considering the age of the machine, it would probably be best to get a new machine, that way you would have a 5 year warranty with it aswell so it's win/win really!
Jan 05, 2013 | Dishwashers
My Bosch dishwasher fills with water but when it comes to the wash cycle it does nothing.
If your dishwasher is brand new, then call Bosch service as they can repair it under warranty.
Feb 26, 2012 | Bosch Dishwashers
My Kenmore ultra wash 6651736 dishwasher broke almost to the month it turned 6 years old and I'm trying to decide if I should fix it or buy new.It washed wonderfully up to the day it stopped .the water...
very common issue on these units, the motor had failed, the motor did have a five yer warranty but we are beyond that.
You can purchase the part from the link below,
Mar 08, 2011 | Kenmore Dishwashers
Hello I'm looking for advise on my 11 year old dishwasher. It's a kenmore ultra wash model # 15812. The problem is that when you push the wash button nothing happens. The drain funtion still works and all...
Hello there:
To be honest with you i would first try these solutions and see if they work cause a new machine would cost a lot of money.
But if you can fix yours it would cost a lot less so plese try these solutions that i have provided below first ok?
If there's no water entering your dishwasher, check these: Water-inlet valve Float switch Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Jun 30, 2010 | Dishwashers
Fills with water when not in use
this is meant to happen
May 17, 2009 | Dishwashers
GE Dishwasher fills with water but does not "spray water" on dish
Here are a few things that might help you out, first is you could have a bad heating element in your dish washer, when it fills with water it has to reach a certain temperature before continuing to the next cycle, next thing is you could have a bad thermostat, or your timer is defective.
Mar 16, 2009 | Kenmore 16522 Built-in Dishwasher
Jenn Air DW961UQW Partially Fills, Drains and Done
is there a diagram of how to replace pump in the jenn=air dishwasher model dw961uqw?? If so is there aweb site I could look at? Thanks Ida Vogegelgsang
May 31, 2008 | Jenn-Air 24 in. DW961 Built-in Dishwasher
Kenmore dishwasher 58715142400 fills but doesn't wash
Motor has gone out..just like mine...Make sure u have voltage going to the motor, (disconnect the plug from the motor) and use an electric meter to make sure you have voltage going to the motor. If so the motor has either gone out or has been blocked by something! If no noise except clicking then motor has gone out. Looking at about $150 for motor.
Jan 26, 2008 | Kenmore 24 in. 15142 Built-in Dishwasher
Kenmore 24 in. 15932 Built-in Dishwasher Logo
234 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
