Question about Nikon Coolpix 4500 Digital Camera
Colors off Something has changed.  In the beginning (years ago) my 4500 got great interior and exterior pictures.  But now the colors are off.  And fooling around with the image in Photoshop doesn't really fix it.  There is an overall underexposure without a flash (indoors and outdoors).  And a tendency to overexposure with a flash (indoors, especially).  And the colors aren't right either.  Although there are a differences between what happens to each color, the general issue is a lack of saturation without flash. Has anyone else experienced anything like this? Curiously, -Jerry-
  • 150 Answers
Re: Colors off
I don't think you'd like to write down all your settings. =)
Of course, make sure your Auto is set, this ensures you are allowing the camera to make all choices for you. If the pictures still don't come out correctly, you may need to have the camera serviced.
If pictures can be taken in Auto mode, but not in (P)rogram mode or others, then give it a try to RESET all options and "start over" like "in the beginning".
The possible reasons are Pg. 91 of the manual:
  • White balance is not on Auto, or incorrect for the lighting conditions. Pg. 92-94
  • The wrong metering makes the lighting evaluation go funny. Pg. 95
  • Bracketing could be set wrong, which makes takes two or three extra pictures with compensation +1 and -1 of your current settings in order to try and capture a better picture at the instant of the original. Pg 116-117 (less likely though)
  • Exposure compensation is set too incorrectly for the conditions. Pg. 108-109
You can find these steps on page 119 of the manual.
To do this follow these steps:
  • Choose a program mode
  • Press the Menu button
  • Goto the bottom of the menu list to choose Reset All
  • Select it and reset all settings
This might have to be done for each program mode.
Please rate a FixYa! ThankYa!
Posted on Dec 15, 2007
0 characters
3 Points
I have a Samsung SL420 camera. Outdoor photos are great. Indoor photos colors always have a gold hew to them. What am I doing wrong. I always use the auto setting for both indoor & outdoor p
You will need to adjust the "white balance". Your camera may be able to do this by pointing it at a gray surface, and setting something. I don't have your camera instructions, but it's a normal adjustment for indoors.
Sep 11, 2014 | Samsung SL420 Digital Camera
My Nikon D70 lcd screen doesn't display correctly the colors on the screen show in bright glowing colors, but the pictures print out great and display well on my computer screen. Is there a setting that...
You are looking at two different monitors with different settings. In most cases you will need to do some editing yourself on your computer because of the difference. Or the brightness can be done in a lab.
Mar 22, 2009 | Nikon D70s Digital Camera
I have a Canon A85 camera that I purchased new about 8-9 years ago. Lately, the pictures are very blurred and have a 'pinkish' /magenta overtone - the actual colors do not come through. I've changed flash...
Its problem of bad ccd imager in your camera and ccd imager will be replaced.
Canon A85 can be repaired Free of Cost by Canon Support as per announced scheme.
Click Canon CCD Imager Advisory for details.
Mar 16, 2009 | Canon PowerShot A85 Digital Camera
No clear color
i had the same problem a year ago / this is not somethin you can fix by yourself
you shood get your camera to a laboratory that repares sony's camera because there is some chip they need to replace - if i recall somethin likr color mannager\spliter i don't have the wright words in english for this
Mar 09, 2009 | Sony Cyber-Shot DSC-F717 Digital Camera
Rainbow colors in screen/pictures
bad connection with the lcd ribbon remove the back locate the ribbon from the lcd there should be two of them and push the ribbons fimly into the connectors
Aug 09, 2008 | HP Photosmart 945 Digital Camera
Pink cast in non-auto modes
Have you tried tweaking the white balance?
Jan 23, 2008 | Canon PowerShot S3 IS Digital Camera
Photo colors are not true on my new Kodak....something wrong?
The Kodak CX4310 is the same as the CX4300 but the 4310 is a Wal-Mart special color. The camera feature that controls color balance is called "white balance" and on the 4310, it is totally automatic. Which means you have no control. If your color is not correct, return the camera. There are not many cameras that use a dock to recharge the camera batteries and connect to the computer. So you will not have many choices if you are looking for a different camera. One camera (without a dock) you should look at, is the Olympus Stylus 300. It is a better choice than the Kodak. It uses rechargeable batteries and the charger is included.
Aug 30, 2005 | Kodak EasyShare CX4310 Digital Camera
Nikon Coolpix 4500 Digital Camera Logo
65 people viewed this question
Top Nikon Digital Cameras Experts
Are you a Nikon Digital Camera Expert? Answer questions, earn points and help others
