Question about Gateway Solo 9550 Notebook
Battery Is there a second battery that can be used with the solo 9550
Re: battery
Gateway Solo 9550 Laptop Secondary Battery (Floppy drive bay)
Sanyo, 6-Cell Li-Ion, Gateway Part Number: 6500604
Model Number: 3UF103450P-2-QC-15
The only place I have found these is on ebay. And only one person sells them.
The ebay ID is “fixmynotebook”. He has one on auction right this moment for $49 bucks.
Once this one ends he should put up another, seem to be selling them off one at a time.
I bought one about a week ago, it was brand new is a factory sealed bag. This is the only place I have found these as everyone lists the 2nd battery for the 9500 as the 2nd battery for the 9550.
AH sorry, doesn’t work!
Posted on Jan 26, 2008
  • 121 Answers
Re: battery - Gateway Solo 9550 Notebook PC Laptops
Get a battery with a close model number
Posted on Nov 13, 2007
0 characters
3 Points
Gateway Solo 9550 bios unlock password master
There isn't one, either take the laptop apart and remove the CMOS battery for 10 seconds or download and burn hiren 15 to a CD and use one of the CMOS password wipers.
Jul 12, 2012 | Gateway Solo 9550 Notebook
I have a Gateway Solo 9550 and cannot get it to come up past the blue screen. Help!
You can put the windows install disk in cd/rom and start the computer up from the disk.when asked to repair push R.. this will start in command prompt link to microsoft help. when command prompt window is up type this .......CHKDSK C: /F / enter. Do not turn off computer until check disk is done..Restart the computer..If you do not have a windows disk you can download MS-DOS portable HERE you can put on a memory stick and start computer up from usb
Oct 12, 2011 | Gateway Solo 9550 Notebook
I need the size or model number for a replacement charger for the gateway solo 9550.
Compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery.
Aug 30, 2010 | Gateway Solo 9550 Notebook
Quick question regarding the Gateway Solo 9550 laptop. I cannot connect to any wifi network. The laptop recognizes networks by name, but it does not connect. Any ideas?
Try clearing your winsock///Click start...Go to run..type cmd....Then type netsh winsock reset. Computer will say need to reboot but not nessasary
Apr 04, 2010 | Gateway Solo 9550 Notebook
My Gateway 9550 will not power on.
The power adapter, dose it match the voltage and the polarity shown on the bottom label of the laptop?
The voltage will be shown in V, for example 19.5V
and the polarity will look like this:
Make sure the charger is the same polarity as the laptop label says on the bottom, if its incorrect it may ruin your laptop.
Sep 11, 2009 | Gateway Solo 9550 Notebook
I have a Gateway Solo 9550 wont boot
it seems issue is very sensitive and without taking look at it problem can not be sorted it can have multiple problems............please contact manufacturer
Sep 01, 2009 | Gateway Solo 9550 Notebook
Gateway solo 9550 invalid configuration error when booting
Please look to see what error you're getting. You are getting one and it will tell you the problem.
May 29, 2009 | Gateway Solo 9550 Notebook
Solo 9550 gateway won't boot up windows
in safe mode.
Go Start>Run type 'msconfig'. select the box that sais - hide mocrosoft
Untick any boxes that arent microsoft products.
On the startup tab, unselect any boxes that are unknown manufacturers or manufacturers like HP/ Yahoo/ etc. Not Radeon or NVid though as they are your graphics
Dec 24, 2008 | Gateway Solo 9550 Notebook
Gateway Solo 9550 will not power on at all.
first you would try the least expensive
make sure your ac adpater works
the plug could be bad on the end
next is the pin inside the dc jack where you plug it in, if the pin moves just a little , you may need a new dc jack sold on ebay cheap
make sure the battery is out when testing
Dec 12, 2008 | Gateway Solo 9550 Notebook
PC Laptops Logo
190 people viewed this question
Top Gateway PC Laptops Experts
Mark Taylor
Mark Taylor
Brian Sullivan
Brian Sullivan
Alex Krenvalk
Are you a Gateway PC Laptop Expert? Answer questions, earn points and help others
