Question about Aiwa NSX-DS55 CD Shelf System
Its a NSX S555, but tis old.
Just a simple question I presume for you. I can`t get a user manual for this model, but need to turn off the timed start. The radio comes on at random times and I want to turn it off, but don`t know how.
Also want to play three CDs randomly. How do I do this please?
  • 38 Answers
Re: Its a NSX S555, but tis old.
Just press TIMER button three times, you'll see 'OFF' on the display and that's it.
I revange - if you already have the manual please send it to
I also try to play CDs randomly - let me know if you know how to do it
Posted on Mar 04, 2008
0 characters
3 Points
Here is a link. All you have to do is search on your item and add the word "manual" Aiwa NSX SZ201 Manuals
Aug 30, 2015 | Aiwa Audio Shelf Systems
Aiwa NSX-A-J800 Manual
Retrevo has the manual for the Aiwa NSX-AJ800 Stereo System here: . You will need to enter a code to download the pdf.
I hope this helps.
(note you will need Adobe Reader or a similar program to read the file)
Dec 23, 2011 | Aiwa NSX-DS55 CD Shelf System
NSX-AJ310 power problems
That's nothing strange!! Mine does the very same thing. It's normal, the system's way of powering up, unless when you turn on the power, clicking noise intensifies....., if that's the case, give me a reply.
Jul 03, 2010 | Aiwa NSX-AJ310 Shelf System
Radio turns on at midnight automatically, I do not have manual to unprogram this
To shut off the timer function (turns the unit on at a certain time):
Press the timer button (on the system itself) until the little clock icon disappears from the units display. This deactivates the timer.
Alternatively, you can reset the system to factory default (clear all user inputs and setting from memory)by:
Start with the power on
Turn the unit of using the power button.
Turn the unit on while pressing the Stop/Clear button.
Here is a link to a PDF version of the manual free to download:
Jan 21, 2010 | Aiwa NSX-AJ20 CD Shelf System
How can I play my ipod on an Aiwa NSX-AJ310?
Simple!!! All you need is an 3.5mm to RCA cable, they're reasonably cheap.
Connect the RCA cable to the auxilliary inputs located to the back of your system.
Insert the 3.5mm jack into the headphone compartment of your ipod.
Turn on your system and then set the function to VIDEO/AUX. It'll be advisable to lower your volume, so that you may not cause any damage to your speakers!!
Play your ipod, make sure that all the volume is up.
Now, gradually turn up the volume on your AIWA system, and the music is supposed to be playing through your system. If not, refer to your manuals.
Hope this helps!!
Nov 30, 2009 | Aiwa NSX-AJ310 Shelf System
AIWA products
Download User Manual for Aiwa NSX-AJ50 Hi-Fi system.
Sony owned Aiwa few years back and you can see NSX-AJ50 page on Sony Support.
If you have Aiwa part Query, please contact nearest Sony Service center.
Oct 04, 2008 | Aiwa NSX-AJ50 Shelf System
Clock on system
Please download Aiwa NSX-AJ310 User Manual here.
Hope this manual will help you to adjust clock time.
Sep 30, 2008 | Aiwa NSX-AJ310 Shelf System
Speakers are making a crackling sound then cut out.
Sounds like an internal loose connection somewhere, possibly anywhere, a connector on a pcb, a dry solder, loose pin on an IC. Tough for an end user to solve this, would entail opening the unit and investigating. I checked the rear panel in the op manual and this model has no ribbon connectors else i'd have asked you to check them.
Mar 26, 2008 | Aiwa NSX-DS55 CD Shelf System
Aiwa NSX-DS55 CD Shelf System Logo
544 people viewed this question
Top Aiwa Audio Shelf Systems Experts
Are you an Aiwa Audio Shelf System Expert? Answer questions, earn points and help others
