Question about Apple iPod MA446LL/A MP3 Player
Unable to reset
The screen shows do not disconnect and is frzen,when plugged into apple pc it does not show as being recognised
  • 2 more comments
  • davemufc Nov 14, 2007
    thanks for info but i believe that the info given was for a windows pc
  • Anonymous Nov 20, 2007
    I went to play my music on my 2 GB iPod. I hit play and it froze. i tried to plug it into my computer, just to get the screen to change but it is stuck on my playlist tring to play.
  • dickel Nov 21, 2007
    I have the same ploblem. The screen shows do not disconnect and is frzen,when plugged into apple pc it does not show as being recognised
  • Bronski Feb 25, 2008
    ipod shows 'now playing' but is totally frozen ....when plugged into pc i tunes will not fire up (but will when ipod removed )
    Sergeant:
  • 314 Answers
Just because a drive icon does not appear on the desktop of your Mac does not mean it isn't seen by the Mac OS. It may simply not be in "disk mode". Did you get the dialog box on the iPod that tells you the battery is extremely low? You will have to allow the battery to fully recharge if that is the case. Apple's website has excellent tips to try for resetting, forcing disc mode, etc.
Try connecting it and then opening iTunes to see if that particular app sees it. You can also use the provided disk repair/format utility supplied with the Mac OS to format the drive in the iPod if it has become corrupted, then use iTunes to restore factory software to it and then re-sync your stuff to it afterward.
Posted on Jan 28, 2008
Go to Windows Explorer where the iPod drive is displayed (mine showed as the G drive. Right click and select Eject.
Viola.
Posted on Jan 26, 2008
This issue is documented in Microsoft Knowledge Base document 297694, "New Drive or Mapped Network Drive Not
Available in Windows Explorer".
http://support.microsoft.com/default.aspx?scid=kb;en-us;297694
Changing the drive letter of your network volume should resolve the issue. If you are unable to change the drive letter of the network volume because your programs depend on a specific drive letter, then you can use the following steps to change the drive letter of your iPod instead.
Important: Changing the iPod drive letter may not affect what letter the iPod uses on subsequent connections, so it is not the best long-term solution. If you are unable to change the drive letter of your mapped network drives, contact your system administrator.
Change the Drive Letter
  1. Open the Control Panel.
  2. Double click on Administrative Tools. Note: If you don't see Administrative Tools, look at the left column in Control Panel for a link that says, "Switch to Classic View," and click it.
  3. Double click on Computer Management.
  4. In the left column, click on Disk Management.
  5. Locate the iPod and right click on it, then click Change Drive Letter and Paths
  6. Click the Change button.
  7. Use the drop-down menu to select a new drive letter. Note: Make sure to choose a new drive letter that is not already assigned to a network drive. The drop-down menu will display all available letters that are not assigned to a physical drive. Drive letters that are assigned to a network volume will still be listed here. It is also a good idea to assign a drive letter other than a, b, c, or d, as these letters are usually reserved for other system drives.
  8. Click OK.
  9. Click Yes on the confirmation dialog.
  10. Close the Computer Management window.
  11. Restart your computer.
Javier Gutierrez
Posted on Nov 14, 2007
Just bought a used apple tv 1st generation and it blinks yellow and white even after I reboot it. It also shows the apple tv with a blinking question mark on my tv screen. How do I fiix to make it work and...
[1] You can restore an Apple TV (1st generation)'s software from the main menu by selecting Settings > General >Reset Settings > Factory Restore.
If you are unable to reach the settings menu, try the following [2]:
  • Press and hold both Menu and down (-) on the Apple Remote for 6 seconds or until the status light blinks amber.
  • The Apple TV should Reset itself and show you a screen where you can select one of the following: Restart ,Run Diagnostics o rFactory Restore. Select Restart.
  • [1] http://support.apple.com/kb/ht3199 [2] http://www.methodshop.com/gadgets/tutorials/appletv-fix/index.shtml
    Jan 14, 2011 | Apple TV MB189LL/A 160GB RTL 160 GB USB...
    When i restored my ipod it still had a white screen and i pulg it out from my pc and i pulgd it back and it wont show on mu pc help
    Welcome to Fixya
    Looks like the software just hanged-up on you. Try to reset the Ipod by following the procedures below.
    1st option:
    Turn the Hold switch on, then back to off.
    Press and hold the Menu and Select buttons for 10 seconds (until the Apple logo appears).
    You may need to repeat the reset several times.
    If the reset doesn't help, then put the iPod into forced disk mode.
    2nd option (Disk Mode):
    Plug the iPod into a high-powered USB port, let it sit for 2 hours, then disconnect it. If you have a wall charger, plug in the iPod, then follow these steps while it is still plugged in.
    Press and hold the Menu and Select buttons until the Apple logo appears
    Immediately switch your figures to press and hold the Select and the Play/Pause buttons until "Disk Mode" appears at the top.
    For a lot of people, this solves the problem. Connect the iPod to the computer and (assuming it shows up) reset the iPod again to get it out of Disk Mode. If at this point you still have the white screen, restore the iPod using the restore function in iTunes under the Summary tab (this will erase everything on the iPod and put it at factory settings).
    Note: Do not disconnect or eject the iPod until the store is totally done. After you think it's done, wait another five minutes.
    Thank you!
    Jan 08, 2011 | Apple iPod nano
    16 gig ipod nano screen has frozen screen
    Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps!
    Jul 08, 2009 | Apple iPod nano MP3 Player
    Ipod wont show up in my computer or itunes help?
    Try reseting it, hold down the "Menu" button and the middle button for about 7-8 seconds, then plug it in.
    Jun 25, 2009 | Apple iPod MA446LL/A MP3 Player
    Ipod touch is locked with connect to itunes screen showing unable to put in code to unlock
    Plug the device into itunes and do a factory reset and restore from backup.
    Jun 08, 2009 | Apple iPod touch
    The words PC showing on camera screen
    Does the word PC show up with the camera connected or disconnected?
    Feb 12, 2009 | Vivitar MAGNACAM Binocular
    Ipod nano 2gb
    Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
    http://www.apple.com/support/ipod/five_rs/
    Mar 24, 2008 | Apple iPod nano
    Frozen iPod nano
    try to put the ipod into disk mode, while connected to PC, perform first hard reset by holding select and menu buttons until it restarts, when quickly change to pressing select and play buttons, then it must go into disk mode, will sync with PC and must show in iTunes, perform restore function to reformat the memory
    Aug 18, 2007 | Apple iPod nano
    Apple iPod MA446LL/A MP3 Player Logo
    130 people viewed this question
    Top Apple Audio Players & Recorders Experts
    Nagendra Baliga
    Computer Repairing
    Computer Repairing
    Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
