Wascomat commercial washer model# W630, Stops in the rinse cycle at different position on dial.
Washer cycle works fine except it stops in the middle of the rinse cycle, even the door unlocks. few minutes later door locks automatically and the cycle continues from where it stopped.
This is a very nice commercial washer. I don't see anything in the manual (230S) that suggests it has a password. The last link is to the maker. Ask them direct.
Find commercial Wascomat EXSM230C washer replacement or repair parts fast at PWS Laundry, the largest worldwide supplier of Wascomat commercial laundry ...
Missing: reset ‎' Must include: reset
Wascomat EXSM 230 S Manual Online: Error Code Cause. 01E Water level not reached within set time. Take necessary action. Press START again.
THIS IS A EXCELLENT WORKING WASCOMAT EXSM230C WASHER. ... LAUNDRY MAT DRY CLEANER PASS THROUGH WASHER WITH HOOD. $3,999.99. + shipping+ shipping+ shipping.
US$4,500.00 · ‎In stock
Our washers are built to last 30,000 cycles and we keep our promise. Years of experience have provided us with knowledge and skills to produce high quality ...
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out. the machine probably has a cold only final rinse so it won't work properly.
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it. Good luck!
Do all of your cycles work when you turn them manually? If one cycle does not work when you turn the dial on it then it will be your timer (The dial assembly $100-up) If all your cycles work manually, then it could be your timer motor which is attached to your timer assembly.
If you turn the dial pass the wash, on to the rinse, does the dial automaticly move (when finishng the rinse cycle)to the spin cycle? If so then your timer motor is ok.
The only wires close to the bottom are the motor, but these should be high enough out of the way.
