What does error code pf mean on the lg tromm front load washer? It starts to run and as soon as the barrel starts to move it goes blank then the pf shows on the screen
PF - Power Failure - PF error code indicates a power failure during the washer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
The "dE" error code indicates that the LG Tromm washer's door has not been properly closed. Closing the door firmly usually clears this error. If the error does not go away once the doors closed, a service technician should be consulted.
Hi, LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit. 1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire. 2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly. Thank you !!
This is a motor overload. Could be too many items in the barrel. I have had this code in the past and took some items out and it went away. I still think there is an underlying issue with the hall sensor or the motor altogether.
Flashing UE - The display shows: • Load is too small.
• Load is out of balance.
• The washer has an imbalance detection and correction system. If individual heavy articles are loaded (bath mat, bath robe, etc.) and the imbalance is too great, the washer will make several attempts to restart the spin cycle. If an imbalance is still detected, the washer will stop and the error code will be
displayed.
Possible Solution
• Add 1 or 2 similar items to help balance the load.
• Rearrange items to help balance the load.
• Control error.
