Question about ASUS P4PE/L (ASU49J) Motherboard
Asus P4pE not booting
I have my computer around three years. When I truned on my computer last night, the fun run few seconds, then stop. Nothing on monitor, only the light is on. I push the start button, nothing happens. I disconnect power, then reconnect, then push start button, the above stituation happens again. What's wrong?
  • jamesinfl Nov 13, 2007
    I turn on my computer, nothing on monitor. the cpu and cooling fans run few seconds, then stop. There is a LED light on motherboard is on. I try restart it, nothing happens. I disconnect it from power till montherboard LED light goes off, then reconnect to power. Try to turn on computer again. Fans run few seconds then off, nothing on monitor.
  • jamesinfl Nov 14, 2007
    The motherboard might be touched by my ex-roommate. What component might be missing?
    Problem Solver:
  • 12 Answers
See the power / restart button is jammed. Many times this happens simply because the restart button jammed and kept pressed. You can try removing restart connector which is coming from the front panel.
Posted on Nov 14, 2007
  • 85 Answers
Re-explain please.
Posted on Nov 13, 2007
  • 1 more comment
  • Shawn Bowman
    Shawn Bowman Nov 14, 2007
    Has the motherboard been touched?
  • Shawn Bowman
    Sounds like a jumper is misconfigured. Let me find the picture for you.
  • Shawn Bowman
    Double check all the jumpers from the below link.
    Download PDF Manual
I realized I need an AGP to connect a monitor to my Asus P4PE-BP. Will AGP 8X work. Specs call for AGP 4X.
The 8x AGP cards will work in the 4x slot. But the 8x AGP card will lose about 1% to 2% of its performance.
Mar 31, 2014 | ASUS P4PE-BP Motherboard
How can i boot or reformat using usb in motherboard p4pe-x, or can i boot from usb from that mobo instead? If so, how? I see on boot setup the removable devices, under that after i click removable...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
Apr 27, 2011 | ASUS P4PE-X (90-M8LAW1-G0EAY) Motherboard
Exployer 8 download crashed my intel asus p4pe with windows xp . I cant boot up. I get the voice welcome, then when it should boot up, it clicks and starts over. Never ending loop.
I would recommend booting your pc to Safe Mode and restoring your system back to a date BEFORE the crash happened. When you power on your pc, press F10 or F8 until you hear a beep. This will bring up a command function for you to select what you would like to boot to . Choose Safe Mode.
Good Luck
Feb 13, 2011 | ASUS P4PE-BP Motherboard
I'm working on a system with a (Asus P4PE Motherboard) hard drive won't boot to post. Just keeps restarting system. Never gets to Post. Also I found a Roach or a Water bug on the motherboard when I was...
pull the ram, unplug all devices and restart. then if you get post, turn off, and add (1) dimm module, and restart. add another dimm and restart. obviously i think its the ram
Dec 15, 2017 | ASUS P4PE Motherboard
Asus Mobo Will Not Boot After Memory Upgrade
not right ram gotta use samusng low density sum mobo so picky
Jan 20, 2008 | ASUS P4PE-X Motherboard
Asus p4pe
Your computer is getting too hot. Get canned air and spray all the dust out, especially the dust in and around the proccessor and heatsink (big metal grille).
Then move the computer off shaggy carpet and move it several inches away from the wall.
If that doesn't wokr you may have hardware incompatabilites, like with your memory or graphics card.
Jan 05, 2008 | ASUS P4PE/L (ASU49J) Motherboard
PC Problem after installing Kingston PC3200 1G in my Asus P4PE-X
As you can see in the manual page 1-13 to use a memory PC3200 you must have a processor working at 800 MHz FSB, now you probably have a processor running at 533 MHz FSB.
Oct 13, 2007 | 3M (EP7630AVR) Video Capture
ASUS P4PE/L (ASU49J) Motherboard Logo
280 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
