Televison & Video Logo
Bill Dougan Posted on Mar 19, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I plug in my Samsung tv model TX-T2082 the red indicator light on the front glows red but no picture or sound could it be the power supply or fuses.
rich2481
Level 2:
Sergeant:
  • Expert 291 Answers
  • Posted on Mar 19, 2015
rich2481
Expert
Level 2:
Sergeant:
Answers
291
Questions
0
Helped
105746
Points
834
Sounds like you dont have the input set correctly..
  • Bill Dougan
    Bill Dougan Mar 19, 2015
    I was watching it when the picture went blank and no sound. It made some noise then went out. The remote has no control over tv when i unplug it then plug it back in the red indicator light blinks a few times then glows solid red. When I press the power button manually there is no change. The model is TX-T2080 manufactured in 2008 I believe its a standard crt flat screen.
2helpful
Samsung TV (model UN40H6203AF) 40" LED. No picture, have sound. Flashlight test can see faint menu screen. Have replaced power supply & main boards to this point. Ideas as to what to do next?
Hi Terry,
If you can see the faint picture in flash light means the power supply and the main board is working. The real culprit is the backlight. Even one bad LED in the backlight will switch off the whole array. To repair this fault the panel has to be opened and the defective LED or LEDs are to be replaced.
This is a complicated, delicate and risky job and must be attempted by an expert only. You may end up damaging the screen permanently if you have not done it before and try to DIY.
How to fix samsung tv tx-t2082 black screen
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. If you wish to get further advice over phone; visit https://www.6ya.com/
I have a white westinghouse 40 inch tv model vr4090 and the tv wont come on it shows the power indicator turn from red to blue but no picture or sound
Westinghouse tx-42f430s wont turn on fix repair - YouTube
? 5:29
https://www.youtube.com/watch?v=DdfLu5RdVEQ
May 12, 2014 - Uploaded by After Hours Tv & Pc repair
Westinghouse model # 32H1G1 won't turn on , but If I unplug the TV and wait for a ... -tx-42f430s-42-inch-lcd-tv-appears-bricked-595806.html ... I have a Westinghouse 40" TV that is working, but sometimes it won't turn on.
Westinghouse LED LCD TV Repair - YouTube
? 12:32
https://www.youtube.com/watch?v=DGg5iuFEfdM
Feb 8, 2014 - Uploaded by INSIDEHARDWARE CHRIS
Westinghouse Model: LD-4680 Similar (LD4655VX LD4255VX ...Samsung LCD TV Repair - TV Won't Turn On - How to Replace Power Supply ...
40 inch Westinghouse lcd tv black screen help - YouTube
? 1:39
https://www.youtube.com/watch?v=tKLRihGgZAs
Nov 21, 2011 - Uploaded by Jason Flynn
SAMSUNG tv LN46C650L1FXZA, red light on front of tv will no power on , no sound, no picture.
What did you "repair"? Usually a no power condition is indicative of the capacitors going bad on the power supply.
Samsung TX-P3075WH blinking red light
Hello
Check its LOT [Line Output Transformer]. Replace it along with Line Output Transistor.
1helpful
2answers
Power Issue
Now,u plug in the tv u get a solid red standby power red LED light in the front of the LCD panel right?When u push the power button on the remote u hear a clicking sound?Only one clicking sound,not the power supply board problems.It the Tuner board problems.But u can make sure it the power board problems or not.By taking the tv aparts check the power board,that board where the a/c power cord goes into it.Look all around the power supply board check for these leakage capacitors,they alway bulges up it top or puff up it top.No bad leakage capacitors,then it not the power supply board problems.
Samsung TX-P2670WH 26" tv squealing
hi there, you do have a problem at the hozintal section, check the FBT and some parts at the horizontal section and at the power supply section. ty
No picture and beeping sound emitting from unit.
We have had ALOT of samsungs in the shop lately and the most resonable solution for these units is just to replace the controll box as a whole. goto www.vancebaldwin.com and login as guest and search for it by model #.
2answers
Flashing "F" on front of drive slot
The front panel display contains seven (7) lights which provide the following information: ? Power-On - Steady green glow indicates that power is being supplied to the Data Silo chassis. ? Temperature Warning - Flashing red indicates that internal operating temperature has reached 43? C (109° F). ? Blower 1 or 2 Failure - Flashing red indicates a blower has failed. ? Power Supply 2 Failure - Flashing red indicates second power supply has failed. ? Power Supply 1 Failure - Flashing red indicates first power supply has failed. ? Mute - When switch is depressed, a steady yellow glow indicates the audible warning sounds have been disabled. Depress switch again to enable sounds. ? Reset - Depress switch to reset chassis and clear any error conditions. The specs on the DS550 do not say anything about an F at all? Did you put the correct model number?
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
