Check out youtube.com, repairclinic.com or appliancepartspros.com search for motor sensor replacement or hall sensor replacement. easy repair. $20 part. 30 minutes time. a know issue on earlier lg washers. lg has enhanced the part to make it more durable. make sure you get an lg part, not an oem equivalent part. part no. 6501KW2002A
SOURCE: I have a LG WASHER,FRONT LOADER WM0532HW KEEPS
LE stands for locked motor error. The first thing you should try is simply unplugging the machine for 10 minutes. If the problem continues the next most likely cause is the hall sensor. To get to the hall sensor remove the back cover, then remove the wheel that is attched to the drum. Undre that wheel if the stator (motor). At the bottom there is a sensor that spans about three of the windings. This is the hall sensor. It is not very expensive. If neither of those work you will need to replace the Stator (motor)
SOURCE: LE code
LE error is a locked rotor you need to have your hall sensor on the stator or better yet just have the whole stator replaced which comes with the sensor on it (P.S. the stator is part of the motor and has a 5 year warranty)
SOURCE: Washer stops with 'LE'
Most likely lack of flow in drain water. Pump inlet could be restricted. I'm guessing it must be sudding up in the rinse cycle and shuts down when it spins up... This is from all the water in the tub.
1. pull the access door on the lower left. You will need a blade (flat) head screw driver for this.
2. You should see a hose. and a knob. Get a small bucket, or 1L soda bottle. Pinch the hose, pull the cap and let the hose drain the water. You might have to pinch the hose and cap it if your bucket gets too full so you can empty it. If you skip this and just open the pump trap, be ready for water to come out, unless it is the inlet port of the pump housing that is blocked
3. After the water is out, you can open the knob for the trap to the pump housing.
4. Make sure the trap is clean. If it isn't, then this is most likely your problem. If it's clean then you want to look into the pump housing before putting the trap back in. Use a flash light. I found a bottle cap ontime holding back the water, when i pushed it water came gushing out.
5. If you can't see a block from this method, either of the follow could be the problem.
A. Pump motor not working or power not starting the pump motor.
B. inlet or outlet hose have a major restriction or blocked.
In this case it will come down to fixing it yourself or calling someone.
SOURCE: "le" on the LG WM0532hw front load washer errror
try unpluging for 45 seconds than hold in the selector knob for 10 sec. & plug back in
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
OVER SUDDSING
