Question about Tivoli (PAL) AM/FM Radio
Tivoli iPal Low volume, can't barely hear on maximum volume and noise when plugged to wall to recharge.
Send it back! I have had 2 fail this way.
Posted on Feb 28, 2008
Why has my Tivoli iPal AM/FM Radio stopped working?
Try removing the battery and power on. If it does not on, replace the unit, a new unit would cost you less that a repair of this unit
May 18, 2014 | Audio Players & Recorders
Bought a used iPal and it only came with a european compatible plug. I bought a US converter. Plugged it in and can't make sense of it. The radio doesn't work. When off, there's no green light....
If the radio has a European-style plug, it's probably expecting 220-volt power since that's their standard. If you got a plug adapter but not a voltage converter, the radio won't work because the line voltage is too low.
Check the radio for a ratings label which will tell you for sure what the radio expects. There may be a selector switch on the back which will let the radio work on our line voltage. Otherwise you'll need to purchase a voltage converter to use the radio.
Jun 20, 2011 | Tivoli (PAL) AM/FM Radio
I have a Tivoli Ipal and I have a broken antenna. I have a new replacement antenna but need to install it. help.
Bought a replacement antenna for my iPal for about $5 plus a couple of dollars shipping. Installed it in 5 minutes without taking the back off of the radio. No big deal. Simple, cheap, fast.
Jan 20, 2011 | Tivoli iPAL AM/FM Radio
The battery is fully charged. It works while connected to the mains, but if i turn it off and remove the power cord (so it works on the batteries) it won't turn on. However, it will turn on while connected...
Change the battery in it. It can be found online. It is easily accessed on the back of the radio, by unscrewing 2 philips screws. I had the same problem with mine, with an old battery. Once turned on, I could unplug it and it would play for 12-14 hours. Apparently the iPal needs a higher voltage when it turns on, so your old battery is not able to deliver that.
Nov 19, 2010 | Tivoli iPAL AM/FM Radio
The volume of my speaker is so low, i cant barely hear it, i cant see anything wrong with it, i checked the AC in, i checked the jack for any short circuit still iget a very low volume out of the speaker...
look on the lower right corner of your screen. there should be a volume icon down there. it looks like a speaker. click that and see if it is set up or down low. if it is low turn it up then it should work. this controls the amount of sound coming out of the sound card on your computer.
Jun 27, 2010 | Creative Labs : Creative Inspire 2900 2.1...
My Tivoli Model One makes a loud screech/buzz noise
I had the same problem and was able to repair it quite easily. Only thing needed is some basic soldering skills.
Problem description:
  • Suddenly a quite loud and disturbing (scratch/screech/buzz) noise appears.
  • Sometimes the noise is gone but it reappears sooner or later.
  • Changing volume or radio band / input (am, fm, aux) does not affect the noise (even on volume turned down all the way).
  • The signal coming out of the Headphones / Rec Out plug is not affected.
Cause:
  • Cold solder joints
Solution:
  • Unplug from mains
  • Remove back panel (the two black screws next to the plugs in the center). The back panel sticks quite firmly, so it might help to remove the front panel first (the 4 screws in the corners) and carefully press out the back panel from the inside. (The other two (silver) screws are used to attach the transformer to the back panel) and need not to be loosened.)
  • On the circuit board at the back panel locate the plug that goes to the speaker (is says "J2"). Check the solder joints. In my case, looking closely, I could see that they're not good anymore.
  • Renew the joints by heating them up and applying some fresh soldering tin. I also renewd the joint from the wire bridge next to the plug. Just check the other solder joints on the board.
In my case afterwards the problem was gone and the device is working properly again.
Apr 03, 2010 | Tivoli Kloss Model One AM/FM Radio
I have a z550i,my media player volume is too low,i barely hear the sound even if the volume is in maximum setting.how can i adjust it?
1. Remove the battery and restart your mobile!
2. Start the media player and goto the "Options / Settings".
3. Select the 'Equalizer' option.
4. Change it from 'Normal' to any other type, like Opera, Jazz, Dance, etc.
5. Now, check the difference in volume of media player!
please rate this advice if it helps ...tc! :)
Jan 15, 2010 | Sony Ericsson Z550i Cellular Phone
Battery won't charge
this is what you should do: charge it.. then when it's still connected to the power switch it on.. then you can remove the power plug and enjoy it for hours...
I know it's weird...
Nov 12, 2006 | Tivoli iPAL AM/FM Radio
Tivoli (PAL) AM/FM Radio Logo
731 people viewed this question
Top Tivoli Audio Players & Recorders Experts
Frank Russell
Frank Russell
Are you a Tivoli Audio Player and Recorder Expert? Answer questions, earn points and help others
