SOURCE: Mitsubishi Outlander 2003 cooling fan issue
I had the same problem. I took my 2003 outlander into the mits. dealership and they told me there was a factory recall for some sort of relay or something for the cooling fan. they fixed it no charge. hope this helps.
darryl
SOURCE: Sholud I purchase a mitsubishi outlander 2003 with 103,291 miles on it for $8495
I have 150,000 miles, no problems. I think a front CV or bearing in in need of replacement. I have replaced the front brakes and rotors. Great on the highway.. 20MPG on the freeway..
SOURCE: remove rear brake drum 2004 Mitsubishi Outlander
Dear Brake Drum Remover,
I'm gonna tell you how to pull this drum off, ya ready?First off, get the rear of the vehicle up in the air safely, Then pull the rear tires off.After those are off then take a gander at the face of the drums, are there shiny brass looking screws installed on the face of that drum?Ifso remove those counterclockwise, then, take a hammer a shock the face off the drum firmly about three times.Now, go to the opposite side on the face of the drum and do that again, keep on doin that until you can wiggle the drum off by hand...easy as that, any other questions get back to me. I'M HERE TO HELP!!!
SOURCE: 2003 Mitsubishi Outlander power window repair. I
just repair the broken wire with heatshrink[after youve respliced it] and check operation of motor.if it works,make sure wiring is securely cabletied out of the way,when reassembled
SOURCE: 2003 Mitsubishi outlander all wheel drive my rear
No solution yet but have same prob on my 03. Rear tires shot after only 10000 miles. NTB gonna diagnose for free. Got 4 tires and 4wheel alignment last year from them. Service mgr thinks it's prob suspension but will prorate michelin tires. Betcha it'll still cost me a thousand. :(
