Question about Empire RH35 Mid-Size Heater
Whistling Heater I have a heater that wil wistle intermittantly when it kicks on. It will do this for about 10 seconds. I does not happen every time, and reproducing the problem consistantly is not possible. Any ideas what is going on?Thanks
  • Anonymous Jan 05, 2008
    Our Empire heater whistles loudly until the burner kicks on. I don't know about any obstructions, will check tomorrow . This started several days ago and is increasing in length and volume.
  • 625 Answers
There may be an obstruction in the burner tube where the gas mixes with air. look for a spider web or similar.
Posted on Nov 15, 2007
What does ILO mean?
Ignition lock out
This happens when a safety feature kicked in and the heater tried to start up again. Turn the power off at the breaker for 10 seconds and try again.
It should fire up or give an error code for possible issues
Aug 04, 2014 | Raypak Rheem RP2100 399K BTU Natural Gas...
Jandy lt250 heater has air flow message
make sure 24 volts ac on both sides of pressure switch if not replace pressure switch or copper tube is plugged if only 10 or so volts will not keep gas valve open
Nov 21, 2012 | Jandy Laars Lt 400,000 Btu Heater
I turn on the defrost and the windows fog up and the car smeels like antifreeze. Also feels like not enough air coming out defrost vents; most air coming out dash vents.It has been using a little water...
Hey Tbs,
You are correct in assuming it will get worse.. if you are leaking antifreeze, it wil not fix itself (DO NOT put any kind of "radiator stop leak" in it) .... take it to a qualified professional and tell them whast happening and let them repair it!! (a radiator shop - NOT the dealer)..
Jun 23, 2017 | 1992 Lincoln Town Car
I need the sheet to correct the wistle noise on the 1004 e moore
The whistling noise may be from an improper air intake shutter control adjustment. For a Natural Gas Unit the air shutter control should only be open about 1/4 " . Also, when checking that, look to see if it's clogged with dust and lint. If so, vacuum it out using a crevice tool on the hose of your vacuum.
Vent-free Gas Appliances should be cleaned and serviced at least once a year. Usually in the Fall before firing it up for the heating season. Twice if you have house pets. Especially one's that shed a lot.
Jan 25, 2011 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
My flame keeps going out. i can press the reset button and some times it will work for a week sometimes only 30 seconds. It is an intermittent igniter. The flame seems to "roll back" when it...
Your GMS unit should not be intermittent ignition but direct electronic ignition. In any case the flame should never roll out of the chamber. There can be a few reasons for the roll out but sometimes a good cleaning of the heat exchanger and a combustion analysis can cure that. The intermittent flame issue is probably a dirty flame sensor and can be cleaned with light sand paper or steel wool. Be careful not to touch the igniter only the flame sensor. It is usually on the opposite side of the burners from the ignition source. Hope this helps :)
Jan 03, 2011 | Goodman GMS90703BXA Heater
Red led blinking three times, furnace kicks on, runs about 10 seconds gas flow stops and it recycles, heats up runs for ten seconds
check flame sencor is clean or loose connection , or it could be the pressure switch try jumping it out and see if it stays on ,
Nov 10, 2010 | Goodman GMS90703BXA Heater
Whistling Bosch AquaStar 2400ES-NG
if you have incorrect gas line size when it kicks on the lack of gas pressure to the unit will cause a wistling. make sure you have enough gas to the unit
Jul 29, 2009 | Bosch AquaStar 2400ES-NG
Empire RH35 Mid-Size Heater Logo
482 people viewed this question
Top Empire Heating & Cooling Experts
Paul Carew
vance jones
Dan Webster
Dan Webster
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
