Laptop on mains power, seems as if screen is lit, as when laptop turned off screen goes black
Try to boot into safe mode by continuous clicking the F10 after you switch on your PC then you may select the safe mode.
Try this link, looks like you need to repair boot:
http://h30434.www3.hp.com/t5/Notebook-Lockups-Freezes-Hangs/HP-G72-b66US-Notebook-PC-Dosn-t-Boot-into-Windows/m-p/1336579#M22150
Testimonial: "Thanks for answering no help I am afraid where talking Windows 8.1 here nothing normal with it worst system on the planet oh for xp or vista thanks again."
SOURCE: Help to repair ACER Travelmate 290LCi
this is normally motherboard or powe side problem check your motherboard
SOURCE: I have a Toshiba A105 Laptop, Screen goes blank after windows....
Here are some easy things that can sometimes resolve this problem:
1) Sometimes there can be a static buildup on the mother board. Power off, remove the battery, remove the power cord and hold the power button in the on position for at least 30 seconds.
2) If that didn't work- Power down, remove the battery, remove the Hard Drive and memory modules and reinsert them. Try to power back up
If these things don't work, get back to me for some more ideas.
Ron
SOURCE: Blank screen on start up on Acer Extensa 4620
If you're hearing the fan, HD and see power lights but still see no display even the BIOS splash screen display then confirm toggle (fn key) to external monitor. No display in either internal or external monitor indicates board level failure.
SOURCE: black screen on Acer 4720Z
If your booting to the splash screen ( ACER Logo screen ) then it goes black reboot - access the bios and do a bios hdd test - you mostlily find your hdd has died. Head scrash
SOURCE: Gateway MA7 laptop
If display issue: connect an external monitor to see if any change.
Could be spyware - boot in Safe Mode (F8) - download, install and run SpyBot (spybot.com).
Good luck.
this acer aspire has windows 8.1 loaded on when I shut it down the last time of use just before it shut down some kind of
app came on screen from top right corner
