Question about Canon PIXMA MP160 All-In-One InkJet Printer
No wireless printing capabilities?
I just got a notebook & a linksys wireless router. Everything connected just fine w/my pc except the mp160. The printer is physically connected to my pc. The software has been installed on my notebook & pc but I cannot print from my notebook. Is it not possible to do this wireless? The documents just sit in queue doing nothing.
Thank you in advance.
  • 85 Answers
Re: no wireless printing capabilities?
Make sure your printer is shared from desktop.
Posted on Nov 13, 2007
0 characters
3 Points
Installing OKI c3400n in Windows 7 32 bit
The c3400n does not have its own wireless capability. It must be connected to a wireless print server or to some wired network that has a wireless access point (WAP) connected to it. A third option is to use a home-networking wireless router.
Individual PCs must have wireless capability also, or they can't print over wireless.
Somewhere along the line the printer must get a local network IP address, i.e. PCs usually use Dynamic Host Configuration Protocol (DHCP) to get an IP address.
But printers are usually manually set to a 'static' IP, because static IPs don't change over time.
Usually there is a security device called a 'firewall' to protect the wired network from unwanted wireless traffic.
So, you first require some form of wireless access.
The people who require wireless printing capability must have their computers configured to make an association to the WAP. Usually requires a passkey or password, depending on the wireless security method.
A port on the firewall must be forwarded to the port used by whichever network-printing protocol is being used to communicate with the printer. There are several possible protocols.
The printer must be set to an IP address unique within the private subnet, i.e., used by the local network.
PC-based network-connected devices use IP (Internet Protocol) addressing, i.e. xyz.zxy.yzx.xzy
The printer must be connected to a network switch that is in some way accessible to the WAP. Residential/SOHO (Small Office Home Office) setups use a combination switch/router device, called simply: a router.
Most of the above is done automatically, but there are some set-up tasks that require user intervention. Electronic devices know how to configure everything, after they are given proper parameters.
All you need to do is check the above items. If the printer is found by MS Windows 'searching for network printers', the hard part is done. Then you just tell Windows to use the network printer.
Jul 22, 2012 | OKI C3400n Laser Printer
Can i print wireless?
Sorry but this printer isn't capable of wireless printing. The only way to connect to a pc is by usb.
Jun 28, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Iam trying to set up a photosmart D7360 to work in my home for all PCs so I'd like to set it up wireless. I'm currently using a router. How do I start? I have a brand ne HP lap top and the photosmart is in...
HP Photosmart D7360 is Not completely Wireless Capable, However if you want to make it Wireless, You will have to use HP bt450 Bluetooth Wireless.
However since this printer has Ethernet Port, you can still make this printer wireless.
You will have to connect this printer thru Ethernet cable ( network cable ) to Router ( this is called wired networking )
Once you have connected the printer to Router, insert the disk in CD Drive and start the installation process, It will prompt you to choose the type of Connection, Choose Wired/Wireless Network and continue with further installation to complete.
How this works,
With any PC that is connected Wireless to Router, You will be able to print wireless from the PC to Printer.
Jul 03, 2010 | HP Photosmart D7360 All-In-One InkJet...
Is a canon Pixma MP160 a wireless printer? I would like to make my printer which I now use a usb cord and make the printer a wireless connection instead, and I cannot find in the manual if it is wireless...
Per the information found here, it is not a wireless printer.
If you purchase a wireless print server (similar to a wireless router), you can connect just about any USB printer to it (which would be practically the same as having a wireless printer).
Some wireless print servers that support USB have a maximum of 2 USB ports and 4 or 5 network ports.
The only problem is the additional effort it takes to configure everything to work properly.
Good Luck!
Jan 25, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Five computers networked with Linksys WRT320N router. Operating systems: Win 7.0 on 3 computers (two hardwired)(one laptop - wireless), Snow Leopard 10.8 on 1 (wireless), and XP on one (wireless). Also...
Sometimes this problem occures when you install a later model wireless router.
Try installing the latest Wireless card driver on the XP computer and the LAN card drivers on the other computers except the MAC.
Dec 31, 2009 | HP LaserJet P2015n Printer
Wireless printing does not work
For an effective wireless connection, the printer should be connected to one of the LAN ports of a configured wireless router. This way, every pc(mostly laptops with wireless capability) can print to the printer. You will need a wireless adapter for desktop pcs to access any resource made available wirelessly ok. Good luck
Jun 02, 2009 | Canon PIXMA MX850 Multifunction Printer
Wireless printer problems
Put the printer on default settings and configure wireless settings on it again.
Apr 21, 2009 | Printers & Copiers
Can I print via my wireless network with HP OfficeJet 6310xi?
Nothing helps. Print servers are capable of connecting a multifunction printer for printing capabilities only. For scanning, you have to connect directly to the Computer or by a Multifunction printer with wireless capabilities.
Jan 15, 2009 | HP OfficeJet 6310 All-in-One Printer...
Lexmark 4300 series
Open control panel to activate your printer in default /check also device manager if your priter are connected w/ device.
Dec 30, 2007 | Lexmark P4350 All-In-One InkJet Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
538 people viewed this question
Top Canon Printers & Copiers Experts
old marine
old marine
Are you a Canon Printer and Copier Expert? Answer questions, earn points and help others
