The camera has been working well until the latch holding the rear memory card door started loosening up. I believe it has a spring mechanism that holds a plastic tab once the door is closed. The tab grabs the inside until it is released with the slide on the outside. Is there a way to repair this spring or order a replacement for the entire door mechanism?
I also own a Fuji Fine Pic Pro (mine is a S3). If there are no authorized dealers around you that can fix your camera I would send it in. Here is a link to send it to Fuji. Send it Priority mail and siginature confirmation. It will cost a little more to do this but it will insure that you know who signed for your camera. Also insure it. Hope this helps.
My camera apperas to be working correctly but will not display pre or postview images on the LCD...
(More)
My camera apperas to be working correctly but will not display pre or postview images on the LCD screen and when I play any images taken they are totally black (as if the picture was taken with the lens cover on!)
my S2 pro will not work on Manual setting..It takes the picture..i can adjust the apperature and...
(More)
my S2 pro will not work on Manual setting..It takes the picture..i can adjust the apperature and speed ok..But after i take the photo it does not write to the cf card..all I get is the hour glass. any clues please ?
the white focus light has stopped working on my fuji finepix s2 pro? do i need to replace a bulb? if...
(More)
the white focus light has stopped working on my fuji finepix s2 pro? do i need to replace a bulb? if so how?
Fuji finepix S2 will not power up at all I now have 2 S2's and an S1 with the same problem. I have...
(More)
Fuji finepix S2 will not power up at all I now have 2 S2's and an S1 with the same problem. I have changed the batteries and done the usual things but nothing at all
