Its shorted, that line, the fuse blew saving you a nice fire.
are you using the correct fuel shown in you operators guide, see index , fuses.
do not mess under dash until you defeat those air bags, they can kill you. (break a neck easy) the schmatic is here.
official FSM
https://suzukipitstopplus.com/Products/1066-2006-forenza-reno-service-manual.aspx
$4 cost, dirt cheap.
first look at the actual horn, see damage there, it or the plug.
pull its plug and safe off (means tape it) and see if fuse blows yet?
always work the simple side first, not air bag side,or the
air bag clock spring, inside, steering last.
its either path A shorted, (most likely but fate wins)
or Path B, shorted relay coil.
if horn unplugged, fixes blowing fuse, the horn is bad.
easy huh?
SOURCE: 2001 VW Jetta Horn issue
replace the horn.thesecurity system should have a seperate horn to the normal "tooting" horn.
SOURCE: power steering light on 2006 suzuki forenza
Power steering light?? Maybe it's something else.
SOURCE: 2008 Ford Escape Horn Fuse keeps blowing after
I would trace the wire from the horn and see if it was inadvertently damaged when the alternator was installed. If you have a voltmeter, you can remove the horn fuse and check to see if there is continuity between the horn (non hot side) of the fuse and the car body. This would indicate a short in the wire running from the fuse box to the horn. You can also look around the alternator mounting area to see if any wires are being pinched. Hope this helps. Good luck!
SOURCE: replace front wheel bearing 2006 suzuki forenza
Very easy. Pull the wheel off after lifting the car on the side you're fixing. ;) Then pull the big center nut off the spindle. It's got a safety smash down you will have to lift up that's in a grove on the shaft. You will see this once the wheel is removed. Unbolt that big nut then pull off the brake rotor. The bearings are in the brake rotor and the shaft the rotor was sitting on. Change them both and be back on your way. It's a 20 min job at most for a beginner.
SOURCE: how do i replace my
2006 SUZUKI FORENZA RECALLS/DEFECTS & PROBLEMS
Access the National Highway Traffic Safety database of 2006 SUZUKI FORENZA recalls and defects found on 2006 SUZUKI FORENZA automobiles. The National Highway Traffic Safety administration is authorized to order the 2006 SUZUKI FORENZA manufacturers to recall and repair vehicles or parts of motor vehicle equipment when its investigation indicates that they contain serious safety defects in their structure, or performance.
Check with your loacol suzuki for recall not sure on this part but it is a common problem
Good luck
