Question about Denon DRA-295 2 Channels Receiver
Memory of radio channels
Each time, when I turn off the receiver all memorized radio station disappear.
On in the stand-by modus they stay in the receiver. What can I do, eg. when I go on cacantion and I want to turn of the receiver? Thank you for your assistance.
0 characters
1 Points
I have and older unit a pioneer VSX 3800, how do you program the radio channels, is there a manuel for these unit i can get sent to myself
You have a digital display pioneer receiver and you would like to know how to store radio stations.
  • first tune your radio to your selected radio station
  • next see if the receiver has a button marked memory, and it should have buttons marked 1 2 3 4 5 6 etc
  • After you have tuned in to your selected radio station, if it has a button marked memory,
  • Press the memory button, then press and hold 1 for a few seconds and that should store your selected radio station to preset 1
  • Next, tune in to another radio station and store it by pressing memory then 2 and that should store it in location 2.
  • If your Receiver doesn't have a button labelled memory, and simply has the store 1-6 etc buttons then ,
  • Tune in to your radio station , then press and hold 1 for a few seconds, it will probably flash a few times until its stored in that location 1
  • Next, tune in to another radio station, then press and hold 2 and that should store it in location 2.
  • repeat.
I hope this helps you.
If so please leave a vote or comment.
Have a great day
Jul 18, 2011 | Pioneer Audio & Video Receivers
I need my radio code
can u explain the problme in detail
Jun 21, 2008 | Audio & Video Receivers
How to store the radio station in memory
You didn't specify the brand or model number of your receiver, but on most receivers you press and hold the preset button in order to store that radio channel. As soon as the station is memorized (usually around five seconds of holding the preset button) you'll see the display blink or you'll hear a sound.
Jan 25, 2011 | Audio & Video Receivers
I want to know how to memorize radio stations. My e-mail is thank you
Could you re-state this in the terms of a product? I don't think we advise on memory tricks.
Jan 22, 2011 | Audio & Video Receivers
Brookstone SLCDv2.0 The device clearly has a Memory capability since there is a "Set" button and the display shows "Memory" when the button is pressed at a particular FM station. ...
Hi, The receiver does have an in built memory to store upto 6 channels.Please follow the steps below to set up the radio memory:- Up to six favorite radio stations (3 AM and 3 FM) may be stored in memory. the following are steps to set radio memory: 1. Press tUnInG/bAnD to select the band. 2. turn tUnInG/bAnD to locate the desired station. 3. Press the M button. the "M" indicator flashes on the LCD Display. 4. Press 1, 2 or 3 to store the selected station. 5. Press the M button again to confirm. 6. repeat steps 1-5 to set other memory stations.
Incase you would require any information do refer the below web site where you could find picture representation of the same.
Thank you for your time and best wishes for your effort.
Jan 11, 2011 | Audio & Video Receivers
I'm trying to find a manual for it. Actually I'm just trying to figure out how to preset a station on the tuner.(Not sure why this page comes up when i search for a manual for it since there is no logical...
Manual presetting
Tune in the desired station with auto or manual tuning.
2. Press the (MEMORY/) ENTER button.
3. Select the desired preset number (1~30) and press the
(MEMORY/)ENTER button.
• "MEM" is flickering for several seconds.
When using the NUMERIC buttons on the remote control.
Examples) For “3” :
For “15” :
For “30” :
• The station has now been stored in the memory.
• When using the NUMERIC buttons, the station is stored
automatically without pressing the (MEMORY/)ENTER
• A stored frequency is erased from the memory by
storing another frequency in its place.
• If "MEM" goes off, start again from the above step 2.
4. Repeat the above steps 1 to 3 to memorize other stations.
Dec 05, 2009 | Sherwood RD-7500 Receiver
JVC RX 809V home reciever
Most times it goes like this:
find your station by manually searching the frequency. When found, press the memory button and in your display the word memory will flash. than press the number you want it stored under and hold it pressed untill the flashing stops.
Other option:
once station is selected, press the preset number and hold it untill you hear a beep or, if the number flashes on your display, it stops flashing.
often you have the possibility to store aprx 10 presets on 1 band, by seleting the band you get new presets for each band, geeting in total 40 preset possibilities.
Let me know if this solved your problem.
Aug 08, 2008 | Audio & Video Receivers
Onkyo tx 902
I have a TX-902 owners manual.
It states:
Classified Memory Function. The memory can be divided for different users or programs of stations.
How to classify stations. With this model, six classes (Class A to F) are available and stations can be memorized in any class. A total of 30 stations can be memorized in any class. A total of 30 stations can be memorized.
1. Tune in the desired station.
2. Press the MEMORY button. The MEMORY indicator will flash for 8 seconds.
3. Press the desired Classified Memory button (one of buttons A to F). The station is memorized in the selected class with the memory number which is the smallest of the unoccupied numbers in the class.
By repeating the operations above, up to 30 stations can be memorized. Any more will produce "FULL" notice.
How to cancel memorized stations:
Retrieve the class number you want to cancel and then press the MUTE/MODE button while holding down the MEMORY button. Another station can be memorized with the memory number which has been cancelled.
Hope this helps.
Nov 20, 2007 | Onkyo TX-8511 Receiver
Setting presets on KLH R3100
No, not so easy, this isn't like your average car radio, unfortunately. This was driving me nuts, too, but I finally found a manual. Hopefully you have a remote, since that is needed.
Once you are on the station you want to save, press MEMORY on the remote. MEMORY will blink on the receiver's display. While MEMORY is flashing, press the button(s) on the remote for the number you want to save the station under.
Sep 28, 2007 | KLH R3100 Receiver
My Onkyo 7.1-Channel Receiver
Take out all the cables unplug from mains for an hour ,plug it back in with no cables connected ,turn volume to full if it turns off its faulty ,if it stays on turn volume to minimum,unplug from mains,connect all cables,turn back on.
Sep 23, 2007 | Onkyo TX-SR604 Receiver
Denon DRA-295 2 Channels Receiver Logo
22 people viewed this question
Top Denon Audio & Video Receivers Experts
Level 1 Expert
Tech Leprechaun
Tech Leprechaun
Are you a Denon Audio and Video Receiver Expert? Answer questions, earn points and help others
