HP DeskJet F380 All-In-One Printer Logo
A
Anonymous Posted on Mar 18, 2015
My printer is just copying part of the page. Leaves out paragraphs of document. I would appreciate any help.
My printer has been leaving out paragraphs of the data. Only copying part of the material. Can you help?
Ravi
Level 3:
  • HP Master 1,682 Answers
  • Posted on Mar 31, 2015
Ravi
HP Master
Level 3:
Answers
1682
Questions
Helped
579367
Points
8910
If the printer is new and you are using for first time, then check for correct printer driver. do a self test page from computer.
If you have been using the printer with the laptop/windows or mac earlier, and it was ok, then check the ink cartridge, replace and try.
Randolph Tidwell
Level 2:
Habit-Forming:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 79 Answers
  • Posted on Mar 18, 2015
Randolph Tidwell
Expert
Level 2:
Habit-Forming:
Cheetah:
Answers
79
Questions
0
Helped
23763
Points
109
Check your printer settings. Try a test print. Call HP Tech Support or YouTube. Also check the scanning surface. Is it printing all the way across, then missing the vertical or vice-verse?
Printing jobs are coming out with the text off the page
Some blank paragraphs may have spilled onto the last page. To view paragraph marks (paragraph mark: The nonprinting symbol that Microsoft Word inserts when you press ENTER to end a paragraph. The paragraph mark stores the formatting you apply to the paragraph.), click Show/Hide on the Standard toolbar (toolbar: A bar with buttons and options that you use to carry out commands. To display a toolbar, press ALT and then SHIFT+F10.). If you see paragraph marks without text on the last page of your document, delete them. Then click Print Preview on the Standard toolbar to view the document as it will be printed and verify that there is no longer a blank page at the end of your document
7helpful
2answers
Brother MFC-7820N Printer--vertical lines
You need to clean the scanner glass. Also known as the strip glass. It is a 1 inch wide strip of glass that runs from the front to the back. Your documents pass over this glass when they are scanned. Some of the wax crayon probably smeared off onto the glass and now when you scan the scanner sees these marks as stationary and thus records them as solid lines. Just look into the scanner section where your documents are fed in or depending on model, some are just to the left of the large original glass.
Good Luck and thank you for using Fixya.
1helpful
My printer leaves black marks down the right side of my documents on every page. I have changed the toner but that does not help. Can I clean the drum?
It may need general cleaning OR have toner stuck to the fuser roller.
Be very careful of the ionizing wires... they are fragile in laser printers.
Xerox WorkCentre 4150, 3 vertical white lines in all feeder scans
the problem is in the scanner, open it up and see if you can find any smudges, and clean any obstruction, any ink, liquid eraser residuals, can cause this part to appear as lines on your copied faxed image.
dont concentrate on the printer this is a scanner problem
1helpful
Sharp Al 1631 prints half a page
Sometimes the originals hesitate using the document feeder, which can cause the problem you are describing. Do you get the same rsults if you lay the original on the glass?
Printer leaves white vertical lines on document
I dont know what kind of copier you have but white vertical lines are virtually always caused by a dirty charge corona.There is usually a little plastic handle, blue, green or grey, that cleans the charge corona.pull it out ONCE, push it back in and try another copy.If you have an operators manual, it should have instructions for cleaning the charge corona.Good Luck, O'scope
2answers
Copy is printiny a shadow of the document also.
check your printer head try to clean or clean it..
any further question let me know ok..
thanks,
Lines on copies and scanned images
I would type it all out but hp has a great little document - complete with pictures!! The issue is that there is something on the small strip of glass that is used for the feeder and needs to be cleaned.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00671260&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
2answers
Scanning document leaves streak down right hand side
hmm this has happened before
make sure it is sitting straight and cleaning it might help
k24674
Grand Canyon Tech
Grand Canyon Tech
