Question about Furniture Rigby Recliner Chair, Power Motion
Power source of the rigby recliner - Furniture Rigby Recliner Chair, Power Motion
    Master:
  • 519 Answers
AC Adapter
Posted on Mar 18, 2015
How can I recline a power seat from a mercedes s500 that's not in the car
find the wires / connector that goes to switch or motor a and using a 12 volt source tap correct lines
Aug 14, 2017 | Seat Cars & Trucks
What type of power connection do I need for this plug
Norm it is not a simple matter of getting a power connection you will need the correct power supply for your recliner .
This might be the power supply unit you will require
however you need to check if the recliner uses 29 volts DC it may be marked on the recliner . You may need to get someone to help you look closely at your recliner to see if there is a label with its operating power voltage and if it is DC or AC and current ..
https://couchguard.com.au/lift-chair/electric/electric/power-supply.php
May 31, 2016 | Computers & Internet
Ford 2008 expedition, power drivers seat won't recline, but everything else works.
Power Recliner
The driver seat has an electro-mechanical backrest adjuster. The backrest adjustment switch is located on the side of the seat cushion side shield and is part of the seat control switch. The recliner motor is mounted to the backrest frame. Power recliners and motors are only serviceable by installing a new backrest frame assembly.
Does yours have Driver and Passenger Power Seats Without Memory Or Power Driver Seat With Memory ?
B1666 Seat Driver Recline Motor Stalled On-Demand If the motor does not operate, Go To Pinpoint Test L . If motor operates, Go To Pinpoint Test M . Take it an have it check !
Does your
May 15, 2016 | Ford Cars & Trucks
AC Pacific, model msc006. Where can I get AC cord and controller?
AC Pacific could be the most likely source.
Jan 05, 2016 | Furniture
Flexsteel electric recliner positioned itself in full reclined position and is now stuck there. Help!
It seems that you have a short in the chair control. You should be able to get a replacement from the manufacturer. They can be contacted at http://www.flexsteel.com/home-furniture/customer-service/contact-us
Sep 09, 2014 | Furniture
We live in a small apartment but would love to have a recliner to sit back and relax on when we come home from work. Is there such a thing as a smaller sized recliner that will not be as bulky and can fit...
Yes, you can a wide variety of small sized designer recliner in one of the best reputed place which is Loveseat Recliner.
Some of the attractive recliner available here are:
a. CLASSIC AND TRADITIONAL BROWN BONDED LEATHER RECLINER
b. COASTER HOME FURNISHINGS MOTION
c. RED LEATHER RECLINER CLUB CHAIR
d. SWIVEL GLIDER RECLINER CHAIR
e. ZERO WALL RECLINER CHAIR, and much more.
innovative-textile-solutions-plush-wing-recliner-protector-recliner-covers-5bjzt1amsw5yuu0bttpforya-3-0.jpg
Aug 09, 2012 | Furniture
2004 Pacifica power seat don't work
I have the exact same problem and I am wondering if you've found the source of the problem??
Mar 31, 2010 | 2007 Chrysler Pacifica FWD New Cars
Horn and power seats quit working. maxi-fuse extremely hot. pulled it out and re-inserted after it cooled down. fixed the problem temporarily (a day or so). swapped that maxi-fuse with the one above it...
which maxi fuse gets hot ? # fuse , plus amps The power seats uses a 30 amp circuit breaker ,not a fuse . The horn gets power from the same circuit breaker . . Sounds like something is drawing to much current. Do you know how to use a amp meter to test current flow . Disconnect componets till draw goes away ? How to use a wiring diagram to pin point areas in a circuit to test ?
Is there corrosion on the pins where the seat circuit breaker plugs into ? Reach under your seats an see if one of the seat motors is hot .
DeVille
The left and the right power seat system consist of the following components:
• The seat switches
• The seat relay modules
• The 4 reversible motors:
- The front vertical motor
- The rear vertical motor
- The horizontal motor
- The recline motor
These 4 motors operate independently of each other.
When the entire seat switch is pushed to the FORWARD position, the forward input of the of the seat relay is grounded.
The seat relay module supplies battery positive voltage (B+) with a ground to the horizontal motor, in response to this input. In order to drive the seat forward, the motor runs until the switch is released.
The BACK position works similar to the FORWARD position with the exception that the voltage polarity supplied by the seat relay module is reversed causing the motor to run in the opposite direction. This action drives the seat backward.
These recline switches operate similar but independently:
The seat relay module could be bad , If you don't know how to do automotive electrical circuit testing it mite be a good idea for you to take your vehicle to a qualified repair shop.
Could have diagnostic trouble codes stored as well .
DTC B0846 +5 Volt Reference Out of Range
DTC B0856 Battery 2 Out of Range
DTC B1656 EEPROM Write Error
DTC B1658 EEPROM Checksum Error
DTC B1982 Source/Battery Voltage High
DTC B1983 Source/Battery Voltage Low
DTC B2101 Recline Aft Switch Failed (Eldorado)
DTC B2101 Recline Aft Switch Failed (DeVille)
DTC B2102 Recline Forward Switch Failed (Eldorado)
DTC B2102 Recline Forward Switch Failed (DeVille)
DTC B2103 Rear Vertical Down Switch Failed (Eldorado)
DTC B2103 Rear Vertical Down Switch Failed (DeVille)
DTC B2104 Rear Vertical Up Switch Failed (Eldorado)
DTC B2104 Rear Vertical Up Switch Failed (DeVille)
DTC B2105 Horizontal Aft Switch Failed (Eldorado)
DTC B2105 Horizontal Aft Switch Failed (DeVille)
DTC B2106 Horizontal Forward Switch Failed (Eldorado)
DTC B2106 Horizontal Forward Switch Failed (DeVille)
DTC B2107 Front Vertical Down Switch Failed (Eldorado)
DTC B2107 Front Vertical Down Switch Failed (DeVille)
DTC B2108 Front Vertical Up Switch Failed (Eldorado)
DTC B2108 Front Vertical Up Switch Failed (DeVille)
DTC B2109 Lumbar Aft Switch Failed
DTC B2110 Lumbar Forward Switch Failed
DTC B2111 Lumbar Down Switch Failed
DTC B2112 Lumbar Up Switch Failed
DTC B2115 Recline Sensor Failed
DTC B2116 Rear Vertical Sensor Failed
DTC B2117 Horizontal Sensor Failed
DTC B2118 Front Vertical Sensor Failed
DTC B2119 Lumbar Forward/Aft Sensor Failed
DTC B2120 Lumbar Up/Down Sensor Failed
DTC 2130 Seat Motor Failure
Aug 10, 2017 | 1997 Cadillac DeVille
Furniture Rigby Recliner Chair, Power Motion Logo
1,099 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
