Question about Compaq Presario 700 470024-192 Notebook
Less reaction when powering on presario 716
When I power on my notebook, led on mainbord gets on, hdd turns, no fan, power on led gets on, battery charging, no sound. I thought mainbord defect but mainbord led is green! looks like power failure!?!?
  • 85 Answers
Re: less reaction when powering on presario 716 - Compaq Presario 700 470024-192 Notebook PC Laptops
Does it beep at all?
Posted on Nov 13, 2007
0 characters
3 Points
Presario M2000 no power or LEDS
That is very possible, but make sure it is not the power supply charger, and remove the main battery to see if you can get power, bad batteries will often load down the power supply, if this works replace the rechargeable battery.
Jun 23, 2012 | Compaq Presario Notebook Notebook
Hi i have a presario cq60-114em, on power up i get the fan coming on straight away, the power and wireless led on, black screen,the hdd led flashes 2x then a pause then flashes 2x and carrys on with this...
1st Steve I would remove the hard drive and power up and see if you can enter the bios by tapping either F2 or Del keys. If you can get into the bios then great. Shut down and refit the HDD. Try and enter the bios again and see if the hdd is recognised. If not then the hdd is finished. If it does show then your windows installation is corrupt. Try starting it up with your windows cd in the drive and point the bios startup to see the drive a 1st boot device. If this works then try and perform a repair of windows from the disk.
Good luck
May 15, 2011 | Compaq Presario CQ60-220US PC Laptop
I have a compaq f572us laptop with vista o/s.Started loading xp and turned the laptop off before fully loading xp.Now it will not boot up. Powers up,led lites come on(hdd,dvd,wireless).
Try these steps in order
After you get it started you will most Likely have to reinstalled windows.
Jan 09, 2011 | Compaq Presario F572US Notebook PC
How do i hard reset compaq presario cq 62
  1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
  2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds .
  3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
hope it helps...
Nov 13, 2010 | Compaq Presario PCCOM2232US Notebook
Hi a philips x51 laptop help - almost dead apart from a few leds
Are you on battery mode?
If you are in battery mode, remove your laptop battery, plug in the adaptor to the laptop (without the battery) and plug to the power outlet. Turn on your laptop.
May 21, 2010 | Twinhead SlimNote N12PI Notebook PC
My compaq presario laptop keeps getting an error: 0211 keyboard error it says press F1 to resume or F10 to setup but neither one of them does anything when I push them. Can this be fixed?
1. Turn off computer and unplug power cord.
2. Disconnect all external devices(open up the computer tower and then )
3. remove battery
4. press power button and hold for 10-15 seconds
5. plug power cord back into computer and press power button.
6. Check LED’s and listen for power supply fan.
7. If LED’s are on or power supply fan starts spinning, watch for boot screen
8. If coputer begins to turn on, turn it off.
9. Reconnect battery and external devices.
10. Press power button and make sure computer starts.
This should work....all the best
May 19, 2010 | PC Laptops
My Compaq Presario f500 series Wont turn on anymore
I would like to help but it sounds like it's over heated and needs a repair guy to look at it
Jan 11, 2010 | Compaq Presario Notebook
Green led mains light comes on, battery amber light rapid flash
This sounds sucky, but you may have a power-supply issue. Especially if you have had to repeatedly press the power-button. If the laptop is new, call Toshiba and see if it's under warranty. If not, find a local computer tech to test your power-supply. This problem is less common nowadays, but still an issue for some!
Hope this helps!
-- RT
Aug 26, 2009 | Toshiba Satellite Pro 4600 Notebook
Compaq Presario F700 turns off just a second after the start button is pressed... any ideas?
try holding the esc button when turning on the notebook the power button light should stay on if the hp logo doesnt come on then turn it off and unplug the notebook and unplug then remove the battery plug the notebook and hold down the esc button and start it let the notebook on for about 1/2hour then turn it off and unplug it put the battery back on and plug it press the power button and it should show the hp logo press f10 to go in to bios then change time and date to current and allso change the boot order
Aug 20, 2009 | HP Compaq Presario F730US Notebook
Compaq Presario 700 470024-192 Notebook Logo
66 people viewed this question
Top Compaq PC Laptops Experts
John mullen
 Mike M
Mike M
Are you a Compaq PC Laptop Expert? Answer questions, earn points and help others
