Question about JVC AV-20120 TV
Picture is blocked by menu box
You can exit menu -word disappear but outline of box remains
  • 4,102 Answers
Try leaving the telly unplugged for 24 hours if you cant exit the menu using the controll is their a back button or exit button on controll you could even try selecting the av channels using av button on controll if the controll is at fault it might be that the pads behind the buttons have become greasy or damp and not allowing you to press it can you change the channels using controll if it is controll prob take apart remove buttons and clean with a dust free cloth if the controll still works and you can change the channels but still have square on screen then it is fault with telly if you unplug it for 24 hours then ry again if you still have problem post back the make n model n age of the set and i will try again sorry couldnt be anymore help ill have another look when no make let me know....................................................................
Posted on Nov 13, 2007
Insignia Service Menu
If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. Service mode entry, adjust and exit procedure to many popular brand TVs are given.
Jan 09, 2014 | Insignia LCDTV26 26 in. Television
Toshiba 23HLV87 HDTV
Please try to unplug the TV from the wall outlet and then rest it for a while pulg it again and test. if still the issues remain then try to see the all the switch menu infront of the TV maybe lock or got errors.
Jul 23, 2008 | Toshiba 23HLV87 23 in. LCD Television
OSD Locks Automatically
Power off your computer and then remove the monitor cable from the port on the back side of the computer case.
Reattach the cable and make sure the pins are correctly screwed in. Power the computer back on and check to see if the OSD lockout message is still being displayed.
Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lockout message.
Find the OSD lockout heading and read the method that your particular model uses to remove the lockout.
Attempt generic lockout removal procedures if you no longer have the manual that came with your monitor.
Press and hold the "Menu" button located at the bottom of your monitor for 15 seconds and wait to see if the OSD lockout message disappears.
Press the "Menu" button again if the lockout message remains on the screen.
Use the arrow buttons to navigate through the main menu options.
Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lockout.
hope this helps
Jun 07, 2012 | HP Computers & Internet
Lcd32880hdf 10 months old. When switched on the picture disappears after 2/3 seconds and will not come back on. Sound still remains un-effected.??
If you can quickly get to menu before picture goes blank, then go picture / backlight / set backlight to minimum and it will work fine.
Jul 04, 2010 | Albatron LNX-21TIS-3 Television
Convergence adjustment for red and blue
Press the MENU/SELECT button
on the remote control to show the
on-screen menu.
to enter the PICTURE menu.
repeatedly until CONVERGENCE
is selected.
to enter the CONVERGENCE
adjust the cross image until the color
outline around it is gone.
Press the STATUS/EXIT button
to exit the menu from the screen.
Aug 21, 2008 | Philips 60P8341 60" Rear Projection...
Display problem
the adjustment box for colour, brightness and contrast stays fixed on the screen. i tried pressing the exit button.... after a few times it disappears only to reappear within a few minutes. also the auto adjustment option, for which we are supposed to manually press the i button, keeps auto adjusting the screen whenever it feels like it. the box appears right in middle of the screen and is a real nuisance as it blocks out the main portion.
Jun 28, 2008 | BenQ FP547 - 15" LCD Monitor
Big black box in the middle of the screen
The black box is there because your closed captioning is on and set to text mode. Some channels send the signal even when there is no actual text to display. You can get rid of it by either turning off closed captioning or changing it to CC1 or CC2 mode instead of text. If you can't find those settings, then restore factory settings as directed in your user manual.
Jun 04, 2008 | JVC AV-32230 32" TV
Need help with PIP
When you go into the menu to choose the PIP source the PIP comes on to confirm that a valid source has been selected. It is normal for the PIP to close when the menu is exited. To display the PIP normally you will need a remote with a PIP button. Most universal remotes today have PIP functions but if you get a Zenith original replacement then you are guaranteed to enjoy the other PIP features such as size, position, freeze and swap.
Jul 25, 2007 | Zenith Z36X31D TV
My pictures are not the quality I expected. What can I do?
Use the Quality setting on your camera to select a picture resolution. To change the quality setting: Press the Menu button. Select Picture Quality, and then press the OK button. Select the Picture Quality setting you want to use, and then press the OK button. Press the Menu button to exit the menu. NOTE: The setting remains until you change it.
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
JVC AV-20120 TV Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
