SOURCE: IJohn Deere whinning noise
Is the device that lowers or raises the loader a hydraulic piston type device, or more of a hydrostatic type device? Whining noises are not uncommon with hydrostatic devices...
SOURCE: Acquired a Kubota BX2200 with house. How do I
What??? I have a BX2200, there is no choke or clutch??? The deck can be in any position????
Check:
1. Make sure it is on Neutral.
2. Make sure the PTO is disengaged.
3. Turn the key until the orange (glow plug) light comes on and count to five, then start.
Is is turning over and not starting, or doing nothing.
Send me a PM.
Dan
SOURCE: kubota t1670 stalls when grass cutting
Is the tractor running fine until you engage the blades? Are you cutting tall grass? There are a couple of reason why it stalls. First, while the engine is OFF, you need to see if the blades move freely, you need to lay down beside the deck and reach up (with a glove on, so you won't cut yourself) and see just what is up under there. Remove any debris, I.E. old grass clippings, and anything else.(see if there is anything wrapped around the column where the blades meet the rest of the deck) Then you will have to grab one of the blades and see if it moves freely. Wiggle it back and forth and find out if all 3 move freely. Sometimes a bearing will go bad in one of the blade mounts and cause the engine to stall. Sometimes the electric clutch goes bad and then you have a whole new set of problems. Either way let me know what is going on. Please rate my answer.
Testimonial: "Makes sense"
SOURCE: where would I find a
Maybe there is a schematic in the owners manual. Check here for one: http://www.manualsonline.com/
