To create a table use the statement CREATE TABLE use the proper datatype with the proper column name
Ex. CREATE TABLE table_name (
column_name1 datatype,
column_name2 datatype,
column_name3 datatype,
For more you can refer to w3schools
For more detail visit us
OK, this should work... First of all, there is one great extension for DW & PHP ADOB object model that is free and great! Download it and install from www.interakt.ro its called PHAKT (NOT impakt, because its not free).
Install it and you will have another type of PHP ADOB document type. Start project with PHP ADOB (not old PHP MYSQL).
Page 1
Create form that has come Editbox and one button. Name Edit box something like e.g. "Search" without quotes. That form should have form action="results.php" and type set to POST NOT, Create Page 2 and name it results.php. Create new recordset in dw like this SELECT " FROM table WHERE table.column.you.r.searching LIKE '%colname%' OR table.other.column LIKE '%colname%' ORDER BY table.tableid this means that we want to select ALL (*) records in table WHERE content of column is similar (Dav, will return Dave, David, Davidof...) to search keyword. Next, in variables click + and add variable name colname default value set to % if you want to show all records if form is submited blank, or -1 if You want to show none if form is submited blank. Finaly for Run-time value type $HTTP_POST_VARS['search'] Runtime value is equal name of Edit box name you set up in first page... Now, from bindings tab, select values and insert it on page, that You would like to show on page. Ill skip this part assuming You know how to format output and how to limit it but if you dont know ask in reply... So now You have page with results. Test it and see if its working. If it is, create page 3 and name it details.php. Now, select value from page that you want to link with details page and click on link. Select details.php page and click on parameters. For param name enter something like id since this should be PK in table and unique value, and for value click on lightning icon, and select primary key in your table. In live page link should be like details.php?id=<some_value>. As for details page recordset it should look like SELECT * FROM table WHERE table.id = 'colname' create vars as for page 2, but change Runtime to $HTTP_GET_VARS['id'] and format output on page. That should be it, but since im typing it in "realtime" maby i forgot something... Home I did helped You.
FAT == File Allocation Table (like a 'Table of Contents' in a printed book)
ALLOC == Allocation
ERROR == ERROR
Some of the contents of that 'Table of Contents' are invalid.
So, copy all the files from the Memory Card onto your computer, to save a copy of those files.
Burn a CD/DVD disk with a copy of those files.
Then, "reformat" the Memory Card, to write a "new" and "empty" 'Table of Contents' onto the device.
Then, copy all the files back onto the Memory Card.
There is a "directory" on the disk-drive, much like a Table of Contents in a textbook.
If that "directory" has been corrupted, i.e., part of it has been overwritten,
then the "Table of Contents" cannot be read, and no listing of available files can be produced.
Windows might say to "reformat" it, to write an empty, but valid, Table of Contents.
Do NOT do this, just yet.
Instead, read online about "File Scavenger" or "Disk & File Recovery" software packages,
that would read through the disk, page-by-page, trying to "stitch" the pages back together,
to create "files" and "folders".
1. Place cursor in each section in which you want hide the page number on the first page.
2. On the Insert menu, click Page Numbers.
3. Clear the "Show number on first page" check box.
You may have to create a separate section for your Table of Contents to suppress the page number on it.
Hello, If you enter a function in the [Y=] editor, and press [2nd][TABLE] a table will be created with X on the left and Y1 on the right. The X list begins at Xmin (in Window settings) . If you scroll up the Y1 list, you will end up highlighting the Heading of the list (namely Y1). If you clear the Y1 label, the whole list will disappear, and the Y1= equation in the [Y=] editor too. To make it reappear, you must go back to the [Y=] screen and enter the function again, then regenerate the table.
If you lost the contents of L2, in STAT, you will have to key it in again.
You can easily modify the formatting for a TOC. You will need to replace the current TOC - I'm assuming you are using the built-in reference to create your TOC.
Select Insert / Reference / Index and Tables. Click on the "Table of Contents" tab.
Click on <Modify>. Click on "TOC 3". Click on <Modify>. Click on the Bold icon to unselect the Bold attribute. Click on <OK> three times.
