Question about Pioneer GM-X962 Car Audio Amplifier
Fuse raiting does this amp, have a fuse raiting of 60amp
  • 1 more comment
  • vacirca Nov 13, 2007
    does the pioneer 760 mosfet ( model number: gm-x962), have a fuse raiting of 60 amps\
  • vacirca Nov 14, 2007
    i know that, but im talking for the power wire set up from the battery, i have the 2-25 amp fuses in the back already
  • vacirca Nov 15, 2007
    so if i am running an 8 gauge wire, with a 60amp fuse, it will not over load the amp and if it does the 2-25 fused on the back of the amp will blow?
  • 631 Answers
It's supposed to have two 25 amp fuses.
Posted on Nov 14, 2007
  • Perry Babin Nov 14, 2007
    The fuse in the main power wire is determined by the size of the wire. The amp is protected by the on-board fuses.
Where the 40 amp fuse for air pump find the power source on the07 GL450 mercedes benz?
Under the hood in a black plastic box with the main 60amp starter fuse
Oct 19, 2016 | Cars & Trucks
Would using a 80 amp fuse instead of a 60 amp fuse in a 1993 Geo Metro cause problems with the starter?
It shouldn't be. The starter is going to pull as many amps as it needs. The fuse is to protect the wiring and keep the car from catching fire in case the starter fails and tried to pull more current than it should. That being said you need to change it back. 80 amps is 33% more current than what that circuit is designed to carry. Being that it's a 1993 you should probably be on your 3rd starter by now
Aug 22, 2016 | 1993 Geo Metro
Nissan presea no power at starter
have you checke dthe main 60amp fuse in the engine compartment fuse box , also some vehicles have a large amp fuse directly attached to positive terminal of the battery on the starter circuit keep me posted if you wish
May 11, 2014 | 1999 Nissan Primera
60-100 amp fuse should be plenty i run my ssl 850 monoblock of 60amp no problem
Feb 27, 2013 | Mutant Car Audio & Video
1998 suzuki esteem 1.6 will not start
G16b engine , in USA>
owned 3, know them too well.
that is alternator shorted out , 1 of its 3 phase huge diodes.
60amps, im looking now.
at real esteem book.
sad but there are 4x 60amp fuses there.
that tells me which branch on tree shorted
here ill do them all
80amp 1 alt shorted
60amp 4 ABS shorted
30amp 5 rad fan shorted
60amp 6 heater short, (HVAC heater blower)
60amp 3 IG , feed 33, feed 15 cab box. with 15amp fuse, (nah)
60amp 2 lamp. (huge )white -blk feed. all have small fues
but. tail light relay? shorted?
off hand if fuse 2,3,or 6 blows,
then the cab box has a huge nasty short to body
or someone was hacking there.
60a-rafhz5f2ue04uln2ew1uxszq-2-0.jpg which one?
Mar 12, 2017 | 1998 Suzuki Esteem
Where do I find the 60amp main power fuse?
Look over on the passenger side under the hood, the starter solenoid is bolted the the inner side of the fender, there on the solenoid will be a few wire bolted to it, some will have a tab on the wire's, those are fuse link's, pull on those one at a time if the wire feels rubbery like a rubber band, then that fuse link is blown. replace it, that's where you get all your power to the truck, main fuse is not like a reguler fuse, fuse link's for that, good luck, hope this was very helpful.
May 19, 2010 | 1990 Ford F150
Alternator charging system
try the 60amp fuse under the bonnut there is a 30/40/50/60 amp fuse,s there the 60 amp is the charging fuse. i had the some thing it was the 60 amp fuse its all ok now the alternator fuse ok 60 amp.
Jan 31, 2009 | Suzuki Sidekick Cars & Trucks
Blowing of fuses
The reason your blowing fuses is the amp needs at the least a 150 amp fuse on the wire that runs to your bat. There are fuse blocks that you can put 4 40amp fuse and theres the high dollor ones that you can put all the way to 200amp. When you trun up your amp its drawing to much current for the little 40 amp fuse that you have and will blow it everytime. I recomend Running a 4 gage wire to bat and ground with same. Get you a 150 or above amp fuse from a car audio shop somewhere. anyway sounds like from what you decribed, theres nothing wrong with your amp just the wires and fuse are not big enouf to handle the current that your amp pulls.
Oct 21, 2008 | Lanzar OPTI 50c Car Audio Amplifier
Pioneer GM-X962 Car Audio Amplifier Logo
54 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
