Question about Samsung SHR-2042 4 Channel Stand Alone Dvr with Cdrw
Burning to disc
I am having trouble burning data to disc i go through the different stages and when it states ready to burn. i press ok and it comes up with no where to back up.can you help please.
  • 1,006 Answers
Witch program do u use to burn disc's???
I recomended you this one ( NERO )
Let me know if u got help?OK?
Posted on Nov 13, 2007
When ready to burn i insert my disc and it says to please insert a blank cd or disc.
Might be your disc contains some data, or the disc is bad, try replacing the disc and see if it works.
May 16, 2010 | Computers & Internet
Burn a Data CD or DVD in Windows 7 Using Media Player
You can burn a data CD or data DVD in Windows 7 using Media Player. An audio CD can contain just approximately eight minutes of music. On the other hand, if you burn a data CD or data DVD in Windows 7 using Media Player, it will be able to hold numerous hours of music. Video files and pictures can also be added to the data discs.
When you burn a data CD or data DVD in Windows 7, the Windows Media Player does not transform the selected files to a different format prior to saving them to a blank data disc, so the files stay in the compressed condition. This allows you to put much more items on a single disc.As the format of the files is not changed, the quality of the files remains the same.
You can burn a data CD or data DVD in Windows 7 using Media Player as follows:
  • Click Start.
  • Click All Programs.
  • Select Windows Media Player.
  • Click the Burn tab in the Player Library.
  • Click Burn options and select Data DVD or CD.
  • Insert a blank disc into the CD or DVD burner of your computer.
  • Close the AutoPlay dialog box if it comes into sight.
  • Some people have more than one CD drive in their computer. If you have multiple CD drives in your computer too, select the one you would like to use in the navigation window.
  • Look for the songs you want to burn.
  • In order to make your burn list, drag the songs from the details pane in the center of the Player Library to the list pane which is on its right side.
  • You can also change the order of the items in the burn list by dragging them upward or downward in the list.
  • To remove a song from your list, simply right-click on the item and click on Remove from list.
  • After you finish making your list, click upon Start burn.
It can take a while to burn a data disc. If your selected items cannot fit in one disc, you also have the choice of burning the rest of the items to a different disc. A data DVD is not the same as a DVD-Video disc ex. the movie DVD you buy or rent from the store.
on Apr 15, 2010 | Computers & Internet
My cd/dvd drive will not burn cd/dvd's properly. it goes through the motions, but the discs come out as blank, i was able to burn cds at 2x speed, but that was it. any movie, or anything else will go...
what kind of application you use for burning??
try it again then double check if you really choose the right path of th drive you want to use as burner..
then you are sure that you burn the music as audio cd not data well as the video cd not data cd..
because if you burn data cd only computers can read that.. not your aplliances like for example your dvd player,cd,etc.
Feb 08, 2010 | Computers & Internet
Cannot burn AVCHD disk. Get this error
The problem with creator 2009 has been fixed by the roxio people.
Instead of burning directly to the DVD disk as roxio software states,
one needs to first save this to be AVCHD movie as a file and then burn directly from the file. This works OK, but as stated this is different
from what the software claims. I'm happy. Thanks
Aug 01, 2009 | Roxio Creator 2009 Ultimate for PC
you need to have a dvd format I use one click dvd it does every thing for me for burning dvds
Aug 01, 2009 | Atlona AT-PC-AVSCOMP Video Converter
Downloading and burning on a compaq presario 2100
If u want Burn the Music CD just select the option copy disc option and it will copy all data to memory then it will automatically ejects and ask for a blank disc just remove the music disc and insert it with a blank disc it will start writing i.e, burning then finally it will come out and u r music disc is ready
U have lot of software to burn a disc most commonly used is
Windows default Windows Media Player
If u Have any doubt or a clarification please describe the problem Clearly
Oct 06, 2008 | Compaq Presario M2000 Notebook
Problem with HD writer 2.0E
The reason for this error is that there is a conflict between HD Writer and other software on your computer. I was trying to find a solution for weeks before Panasonic advised me to remove other DVD burning software on my computer. I therefore removed Pinnacle and DVD decrypter (which I believe was causing the problem), reinstalled HD Writer and then everything worked fine. Note however that the DVD-RW discs I had tried to use before were corrupted and couldn't be reformatted and therefore once you have removed the other software and reinstalled HD Writer, start again with new DVD-RW discs. Good Luck.
Jul 23, 2008 | Panasonic HDC-SX5 DVD Camcorder
Burning failed
dis type of problem comes when lens sensitivity gets low n it is not capable to write nything..
it also caused when dere is sm dust inside lens due to it....
it is unable to read or write....
if u hv lens cleaner for pc clean ur lens n try to burn again...
if same problem comes than it is sure dat urs lens sensitivity gets low.....
if it creates more problem ask me.....
Jun 15, 2008 | CyberLink SW- DVD Software Power DVD...
Nero burn CD with different speeds.
Your burner can only achieve high speeds towards the end of the burning progress as the data burned reaches the outer areas of the disc. Burning starts at the center of the disc - the more the laser moves towards the outer end, the faster the burning speed gets. I have a 20x burner and 18x discs, and every burn starts at about 6-7x and then gets progressively faster, until the last 20secs of the burn it actually burns at 18x.
Feb 19, 2008 | Ahead Software Nero 6.0 (60045) for PC
Iomega CD-RW 52x24x52 External Burner wont burn
have you checked the web site for drivers update and which burning software are you using if you are using on board xp stop using this and got for nero burning if you are on xp sp1 and try and upgrade to xp sp2 or win 2000 sp4 and clean cd lense and try that if same resaults it's time to redo windows as you may have currupted dll files and change usb leads over if possable
Aug 13, 2007 | Iomega (32885) CD-RW Burner
Samsung SHR-2042 4 Channel Stand Alone Dvr with Cdrw Logo
76 people viewed this question
Top Samsung Home Security Experts
Gary Banta
Level 1 Expert
Cesar Quant
Cesar Quant
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
