Question about Gateway 7330GZ Notebook
Screen problems My Gateway 7330GZ Notebook's screen goes off after 2 seconds
My screen has gone sideways how do i put it back to normal
Posted on May 31, 2008
  • 85 Answers
Try the power save options.
Posted on Nov 13, 2007
My gateway 7330 will not reboot.white letters and black screen er
format your system and re install Windows,
this is master boot problem.
Jun 30, 2009 | Gateway 7330GZ Notebook
Blank screen
When u power up the computer press "del" or F2 key then check your harddisk is detected or not.
Also load optimal defaults settings.
then restart the computer press F8 key then enter in enable vga mode.then change screen resolution to 1024*768.
Please let me know.
Jun 06, 2009 | Gateway 7330GZ Notebook
Laptop LCD Screen won't come on and computer keeps rebooting
Try checking the inverter, if that is intermittent, it could short the system and cause the symptoms you are describing.
Apr 03, 2009 | Gateway 7330GZ Notebook
Notebook Gateway 7330GZ won't boot
Hm...That sounds like either the motherboard is dying/dead or a device is (such as the hard drive). I would suggest removing one piece at a time and see if you can get past that screen. The most annoying would be if it is the DVD drive since it's probably the most difficult device to remove from the laptop. (If memory serves it involves removing a certain screw from the bottom and then getting under the keyboard so you can push it out).
Do you have a second stick of RAM installed? Mine died a while ago and caused real heck with my 7330GZ.
Nov 16, 2008 | Gateway 7330GZ Notebook
Power jack repalcement Gateway 7330GZ Notebook
you have options....#1 send it out to gateway for an arm and a leg...(i have the same model and had the same problem), #2 find a local computer repair store...they will most likely charge about 30 for the part.(that's what i was charged + 60 an hour for labor took 2 hours...) or #3 do it yourself, if you can solder then i can talk you through most of the dis you can get the part remarkably cheaper
Nov 08, 2008 | Gateway 7330GZ Notebook
Look for cracks in the hinges. It is a big problem with the Gateway 7330GZ.
Sep 30, 2008 | Gateway 7330GZ Notebook
Gateway laptop 7330gz
Some possible causes
--Some laptops have a function key that can turn off the screen when you have an external monitor running. Check your documentation to find out.
--The lamp burnt out.
--Cover switch (when you close laptop) is stuck/jammed/loose.
Sep 15, 2008 | Gateway 7330GZ Notebook
Gateway 7330GZ PC Notebook screen going off and on
Ya, my 7330GZ has been having this problem. I did end up taking the screen apart.
Removing the little black nubs around the screen allow you to remove the screws, then you just use a flat headed screw driver to unclip around the edges (some can be stubborn, especially along the bottom).
The screen is glued to the casing along the top and bottom, so you have to gently separate the two.
After you have it opened up the screen has 3-4 screws along the left and right side (the right side is a pain to unscrew since the wireless antenna casing runs right along it).
Once you remove those screws you can take the screen out and get access to the ribbon cable running along the back.
Aug 11, 2008 | Gateway 7330GZ Notebook
Backlight problem
After doing much research, as I have different but screen related issue the Inverter Circuit Board is bad and needs to be replaced.
Mar 29, 2008 | Gateway 7330GZ Notebook
Gateway 7330GZ Notebook Logo
91 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
